Author Topic: dashboard light gone off  (Read 1034 times)
tony1979
« on: 19 May 2011, 22:08:25 »
hi i wonder if someone can help me as i am very desperate  dashboard lights,speedo/climate,cigarette light all switches gone off on my omega 2.2dti cdx 02 reg . fuses are all ok
dimmer ok any ideas :'( :'( :'(
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: dashboard light gone off
« Reply #1 on: 20 May 2011, 03:16:35 »
are you sure maybe a dodgy fuse. would need to test it. also when did it happen on road or parked up.
Solar charger fitted.
If not Broke dont fix it..
tony1979
« Reply #2 on: 20 May 2011, 21:50:50 »
check and verify all fuses at least 5 times .it happen when i start the car one evening 3 days ago i also bought and replace  3 headlight swiches and check all the wiring on the back of the swiches and fuse box .thank you for the answer :-/
« Reply #3 on: 20 May 2011, 22:03:53 »
Disconnect rear ciggie/accessory socket see if it makes any difference
