Author Topic: auto gearbox prob  (Read 1755 times)
mantagte
  • great yarmouth
    • omega bmw maverick
auto gearbox prob
« on: 02 June 2011, 19:34:12 »
car sluggish no go
checked auto box oil
loads came out of filler hole
car is level
was expecting red oil
got lightish brown yuck
what gives?
Re: auto gearbox prob
« Reply #1 on: 02 June 2011, 19:36:36 »
car is level ......
............ and the engine was running & had been cycled through D & R  ::) ::) ::) ::) :y
but it sounds as though you're over due an ATF change if what's in there is brown  :y
« Last Edit: 02 June 2011, 19:37:36 by Andy_B »
« Reply #2 on: 02 June 2011, 19:38:38 »
Was the engine running, gearbox warm, gearbox in neutral, car level ???
Those are the parameters for a CORRECT check of the level.
Even given those parameters it is expected that some oil will leak out as there is a physical change to the ATF as it gets old ... simply put the polymer chains that the ATF is made of get longer as the oil gets old/breaks down. Longer chains take up more room so the oil sort of expands !!  If that makes sense. ....   :)
Oil is red to start with but changes colour over time/use. Even if you were to drop both sumps you would only change half the ATF .. so it still would not be red after even a short run as the old mixes with the new .. :)
mantagte
  • great yarmouth
« Reply #3 on: 02 June 2011, 19:47:57 »
engine was off
car was cold last used yesterday
So an oil and filter change should cure the problem?
« Reply #4 on: 02 June 2011, 19:48:48 »
You sure about that mate - ATF consists of long polymer chains which break down (shorten) with age and shear.  Never heard of polymer chains growing with age.
« Reply #5 on: 02 June 2011, 19:54:26 »
OK .. perhaps it's t'other way .. :(  .. but the net effect is that the ATF expands as it gets old ... do lots of sheared chains take up more room than the original unsheared ons ???
Old oil takes up more space than new oil .... I know that bit is correct !!!  :)
« Reply #6 on: 02 June 2011, 19:55:31 »
engine was off
An ATF change won't do any harm.  ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1289757627
why didn't someone say the link didn't work?  ::)
« Last Edit: 02 June 2011, 21:51:23 by Andy_B »
« Reply #7 on: 02 June 2011, 19:58:21 »
Yep you got it - knew my B Sc Hons in Polymer Technology would come in useful one day  ;)
mantagte
  • great yarmouth
« Reply #8 on: 02 June 2011, 21:45:00 »
how much oil do i need ?
it is d111 isn't it?
« Reply #9 on: 02 June 2011, 21:49:00 »
You'll need about 5 or 6 litres http://www.omegaowners.com/forum/YaBB.pl?num=1289757627
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #10 on: 02 June 2011, 22:48:24 »
car sluggish no go
car is level
what gives?
Lightish brown yuk, hmmm, are you Sure the oil cooler in the rad is ok and not leaking coolant into it, normally old ATF is dark and very smelly
« Last Edit: 02 June 2011, 22:48:55 by henryd123 »
other rides
mantagte
  • great yarmouth
« Reply #11 on: 02 June 2011, 23:08:06 »
its not watery/oily like when hg goes
its like its been cooked its very thin
like water but still oily to the touch
mantagte
  • great yarmouth
« Reply #12 on: 03 June 2011, 18:02:06 »
ok changed oil/filter
car is still sluggish
til put in 1st then
it seems to go 1st-4th
reverse is fine
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #13 on: 03 June 2011, 19:38:48 »
Right my tip. I am going to call it Varches Fix.Lift bonnet and check that every relay and plug is actually seated(fully home) next the battery. There is a big blue plug in particular. My theory. Rough roads and potholes.
Free give it a go, you never know..........................
mantagte
  • great yarmouth
« Reply #14 on: 03 June 2011, 23:14:18 »
sorted, broken wire 6 inches from ecu
thanks for the idea varche :y
Page created in 0.025 seconds with 20 queries.
