Author Topic: A/C condenser  (Read 2297 times)
tport
  • east mids
A/C condenser
« on: 04 June 2011, 23:33:43 »
As well as having a leak in the low pressure A/C pipe, I have also found a new leak at the bottom of the condenser.  I'm hoping that this is the last leak as I can't find any UV dye anywhere else under the bonnet.
How easy is it to change the condenser on a facelift car with an auto box and where can I get the best value parts?  The howto guide looks fairly straightforward but appears to be for a manual 'box.
« Last Edit: 04 June 2011, 23:45:05 by RobG »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: A/C condenser
« Reply #2 on: 05 June 2011, 00:02:25 »
Pretty straight dorwars to remove the condensoe mate.
Bagpipes, radiator, a few connectors to unplug
tport
  • east mids
Re: A/C condenser
« Reply #3 on: 05 June 2011, 17:46:02 »
Thanks for the advice, I have ordered a replacement from airconparts.co.uk.
I guess the O-rings will need replacing, does anyone know the part numbers and costs for these?
Re: A/C condenser
« Reply #4 on: 05 June 2011, 17:48:15 »
I wish I'd thought about getting new seals before I did mine the other week. I'd to re-use mine, but the system vacuum'd down OK & there was no signs of any leak.
Re: A/C condenser
« Reply #5 on: 05 June 2011, 22:49:51 »
2nd hand one from a 3.0 in mine, original seals still sealing. :y
Hardest part was keeping the rad far enough away to drop the condensor and its plumbing in and then securing the plumbing between the battery and radiator.
Would have been easier to whip the radiator out completely. ::)
« Last Edit: 05 June 2011, 22:50:20 by 05omegav6 »
Re: A/C condenser
« Reply #6 on: 05 June 2011, 22:56:05 »
I'm amazed you even managed to get the condenser out with the main rad still plumbed in.  :-? :-?
Re: A/C condenser
« Reply #7 on: 05 June 2011, 23:02:10 »
Folded in half carefully wriggled :-X
To be fair, it was already mullered, most of the fins were missing  :o
Re: A/C condenser
« Reply #8 on: 05 June 2011, 23:04:55 »
how about the 'new' one? You couldn't force that in just in case you damaged it.  :)
Re: A/C condenser
« Reply #9 on: 05 June 2011, 23:13:01 »
 ;D
Borrowed a second pair of arms to hold the radiator as far up and out of the way as poss.
Bit fiddly. :-/
Re: A/C condenser
« Reply #10 on: 05 June 2011, 23:26:26 »
;D
Bit fiddly. :-/
I just took the rad out, strangely it seemed to have grown while it was out of the car as I'd to 'persuade' it back in.  :-? ;D ;D
