Author Topic: Rear Blind  (Read 3400 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Rear Blind
« Reply #15 on: 23 May 2011, 19:03:04 »
But you'd think this the blind woudv been made such a away that when its closed it 'home' and nothhing should happen to it. got a mate with a Nreg bmw 525, hes had it for 10+ yrs, rarely uses it but still works at the touch??  :(  :y
Anything which is designed to move will go belly-up if it isn't used.  Look at your joints, as an example.
they still move  ;) sometimes  ;D ;D ;D ;D
Re: Rear Blind
« Reply #16 on: 23 May 2011, 20:44:18 »
I would suspect mine gets used at least daily in the summer - goes up when I park, as it does help the temp reaching that of a nuclear reactor whne parked in sun
Re: Rear Blind
« Reply #17 on: 23 May 2011, 20:48:08 »
Mine only gets lowered when SWMBO drives it, all other times it's up.  ;) ;) :y
Shimmy
  • St Albans
    • Omega 3.2 Elite
Re: Rear Blind
« Reply #18 on: 23 May 2011, 22:54:19 »
Mine doesn't work, cba fixing it either.
Would only use it in the summer if I remembered when parked up, rest of the time I like to use my rear view mirror a lot.
Budget tyres, false economy.
Re: Rear Blind
« Reply #19 on: 23 May 2011, 23:38:21 »
I love my blind. Up down up down all day. Novelty value i suppose. Not worn off yet. Although it's only been  installed a fortnight. :D
Re: Rear Blind
« Reply #20 on: 23 May 2011, 23:42:09 »
I love my blind. Up down up down like a tarts drawers. Novelty value i suppose. Not worn off yet. Although it's only been  installed a fortnight. :D
How crude. ::) :D
Re: Rear Blind
« Reply #21 on: 24 May 2011, 09:18:03 »
How crude. ::) :D
Your not funny Albs!  ;D
51M0N
  • Hull
Re: Rear Blind
« Reply #22 on: 24 May 2011, 09:32:13 »
novelty value of the blind is brilliant haha. Although mine doesn't pop up as gracefully as it used to  :-[
Re: Rear Blind
« Reply #23 on: 24 May 2011, 12:43:49 »
You've never looked through your blind then have you  :-?. You can see through the back window almost as easily with it up as you can with it down  :y.
bootie
  • Enix, Almeria, Spain
Re: Rear Blind
« Reply #24 on: 25 May 2011, 18:17:45 »
Is it possible to supply dimensions then please, closed, length of blind/travel, depth when not in use to see if there is enough room in the tailgate behind the card, if the rear wash wipe would foul it etc, etc.
Thanks chaps
whitebullet
  • stoke
Re: Rear Blind
« Reply #25 on: 15 June 2011, 16:53:03 »
well i was playing with the button for the rear blind while i was sitting in traffic, needless to say i shit myself when the blind went up, i have lubbed it and make it go up and down every time i used the car, so far so good
HALFORDS TRADE CARD HOLDER
VAUXHALL  TRADE CARD HOLDER
