Author Topic: 2,5 V6 working bad! please help  (Read 2059 times)
Aivaras
« on: 14 June 2011, 09:03:48 »
my V6 is working not propertly, here is the video: http://www.youtube.com/watch?v=WGYVZyFhuUA
i don't know what can i do, i can all car electrical parts change but have no results, i am jus guessing what could be the reason of working like this.. Crankshaft sensor? TPS sensor? ignition coil?
Aivaras
Re: 2,5 V6 working bad! please help
« Reply #1 on: 14 June 2011, 09:09:48 »
also i have to say that i have changed the engine from vectra to my omega (with metal cover gaskets), but all sensors and electrical maintenance i left from ex-engine. in the begining work was great, but after half of the year began to work noisy, also fells big vibration of engine, and there are not many torque left, from 170PS it seems that left just about 120PS. Also one of the intake solenoids valve not working (upper).
« Reply #2 on: 14 June 2011, 09:25:56 »
Try the paper clip test or pedal test depending on wwhat year your car is.
Aivaras
« Reply #3 on: 14 June 2011, 12:18:58 »
just 136 fault came up. what does it means? also maybe these problems can be because of automatic gearbox faults? when i checked it result were: to replace change TPS sensor( but i don't know if that can solve everything), also some other faults about ignition/injection cutoff valve no signal and low or high voltage (i don't remember, maybe 84 or 89 fault)
« Last Edit: 14 June 2011, 12:34:11 by neillas »
MutantCav
  • Gainsborough
« Reply #4 on: 14 June 2011, 16:02:11 »
If you have metal cam covers on be absolutely sure to clean out the breather system otherwise rather than leaky cam covers you will get a damaged crank seal or something like that :y
Aivaras
« Reply #5 on: 14 June 2011, 16:47:30 »
i already did that twice ;)
« Reply #6 on: 14 June 2011, 19:25:01 »
Try it with the maf sensor disconnected  ;)  If its ok/better your sensor is dodgy.
Read the codes (or pedal test) - do you have a code 19?
Aivaras
« Reply #7 on: 15 June 2011, 06:57:12 »
no, just codes: 136 and 31(it is normal). also i tried to swich maf sensors, but there was no change. And electrical testing of multi-plug pins showed good working results, as in Autodata required.
« Last Edit: 15 June 2011, 07:00:15 by neillas »
geoff
  • thornaby,stockton on tees
« Reply #8 on: 15 June 2011, 07:49:10 »
looks like idle control valve  :y :y :y :y
Aivaras
« Reply #9 on: 15 June 2011, 09:20:00 »
but this revs jumping is just when working on LPG. on petrol there are no sympthoms of Idle control valve working bad. So if can be so stong difference between petrol and LPG because of oxygen sensors? one of them is NGK universal o2 sensor, other is Bosch (3wires). vibration is all the time, on petrol and on LPG.
i don't know what to do, i'm tired of this...
geoff
« Reply #10 on: 15 June 2011, 18:01:15 »
did not know was lpg,best off have someone who know about lpg a lpg expert to have a look at it,but still thpught icv would still have something to do with the bad tick over and cutting out  :y :y :y :y
