Author Topic: Bad engine rattle :-(  (Read 6523 times)
Re: Bad engine rattle :-(
« Reply #30 on: 07 January 2011, 10:35:08 »
quick question to kevin....are the 2.5 & 3.0l oil pumps the same do you know?
...just checked, they both come up with
 part/no. 9193203 :y
Can't see why they wouldn't be, but I believe there was a change at some point during production that required a change in the T-vents in the head to give the right oil flow to the cams and lifters.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #31 on: 07 January 2011, 10:38:40 »
 part/no. 9193203 :y
thats right, dont know when/year though.
« Reply #32 on: 07 January 2011, 10:38:49 »
Hmm, I know your right..  :-)
Do you want to sell your spare heads?
I reckon Ill change the oil pump too while Ive got it apart. Is it possible to do while the engine is still in the car?
I would say: Drop the sump, clean out any debris from the pickup strainer and have a quick look at a couple of the big end shells. This will tell you if there was a wholesale lack of lubrication.
If everything looks OK, I would say it's more than likely that it was a timing issue, so refurb / renew the heads, check / clean / replace the lifters and see how it goes.
Pip
  • Exmouth
« Reply #33 on: 18 January 2011, 11:08:07 »
I have removed and stripped the engine right down now, the oil was like treacle which starved and seized the top end. The oil pump, mains and bores are all OK, the big ends are just starting to show a little wear so Ill replace them while its apart.
One of the inlet cams hasn’t been able to turn as the tappets seized but the pulley wheel wanted to keep going and cracked the cam where it locates on the pin.
Unfortunately Vauxhall no longer carry cams for the X30XE. Does anyone know where I might be able to get an inlet cam (marked G8), or failing that suggest an alternative set of cams?
Cheers Phil
« Reply #34 on: 18 January 2011, 11:14:38 »
Cheers Phil
I have a set of 3.0 cams but unfortunately its not worth splitting them because the 2.5 boys like them as on upgrade ::)
Pip
  • Exmouth
« Reply #35 on: 18 January 2011, 19:40:21 »
How much would you want for the full set?
Pip
  • Exmouth
« Reply #36 on: 20 April 2011, 20:14:06 »
Ive eventually started on the rebuild, replaced all the bottom end bearings, heads, cams and rings along a really good clean up.
But putting the cam pulleys back on this evening I notice they can go two ways, I am guessing that it doesn't matter which way but if someone can confirm, that would be great.
Also noticed the crank pulley for the cam belt has lost its locating notch on the inside. Can anyone help with a spare one?
Cheers
Phil.
« Reply #37 on: 20 April 2011, 21:12:20 »
Hi Phil.
The cams have locating pins so cam 1 is the drivers side exhaust cam, the 2 drivers side inlet 3 passenger side inlet and 4 passenger side exhaust ;)
Pip
  • Exmouth
« Reply #38 on: 20 April 2011, 21:34:26 »
Thanks for that, Ill have to double check which one Ive fitted where, but whats was worrying me was the pulley will go on two ways too even though the holes in the pulley seem to be off set.
« Reply #39 on: 20 April 2011, 22:00:37 »
Yeah but each slot has a number ;)
« Reply #40 on: 21 April 2011, 09:44:49 »
This might be handy when re-fitting the cams:
http://www.omegaowners.com/forum/YaBB.pl?num=1152565319
Pip
  • Exmouth
« Reply #41 on: 21 April 2011, 11:49:05 »
Thats brilliant, thanks.
Now I know Ive got the cams in the right places, but that diagram will help me get them positioned right and the pulleys fitted.
Just what I needed, Ideal.
Pip
  • Exmouth
« Reply #42 on: 21 April 2011, 20:14:11 »
All sorted now, I hadn't seen the numbers stamped on the front of the pulleys as the washers were in the way, easy when you know how.  :)
The Red Baron
« Reply #43 on: 27 April 2011, 08:15:57 »
good to hear the rebuild is going good. :y
Pip
  • Exmouth
« Reply #44 on: 01 May 2011, 20:46:37 »
Unfortunately its come to a bit of a full stop now, Ive spent knocking on £800 on parts alone now, as well mostly finished doing a LPG conversion but can't get a front pulley :-( and not done enough posts yet to be able to list in the wanted section.
Pages: 1 2 [3] 4  All   Go Up
