Author Topic: ABS & Traction Light On  (Read 1125 times)
Jimmy Jerms
  • Kent/London Border
« on: 29 June 2011, 18:59:08 »
I recently did some work on the front suspension and had to disconnect one ABS sensor. Couldn't get it off of the hub so just disconnected at the plug. During reassembly I started the car with the sensor still disconnected. When all back together found the lights still on even though the sensor is connected. Does this have to be reset manuallly? Can I do it myself?
Re: ABS & Traction Light On
« Reply #1 on: 29 June 2011, 19:07:00 »
Not seen that before. Certainly needs a reader on it I think.
Any chance you damaged the sensor?
Jimmy Jerms
« Reply #2 on: 29 June 2011, 19:14:51 »
Its possible. I did tap it a few times and tried to get a flat blade behind it to lever off but it's not visibly broken in any way.
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #3 on: 30 June 2011, 07:32:07 »
Check its resistance against the other front one as an indication of whether its faulty or not.
Alan
Page created in 0.024 seconds with 20 queries.
