Author Topic: She wants to overheat?  (Read 1475 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« on: 10 July 2011, 13:03:40 »
Hello, I just came home from work but didn't  know if I will make it. Doing around 90 mph on highway after some 30 km temp gauge started to rise slowly to almost 97/98 degrees. Stopped for a few minutes and checked - no oil in water, no water leak, both fans running, no oil leak, no mayo under oil cap. She has new rocket cover gasket, new water pump.... It' s 33 degrees outside in a shadow.... What could it be ?
danzigfan
Re: She wants to overheat?
« Reply #1 on: 10 July 2011, 13:41:34 »
« Reply #2 on: 10 July 2011, 14:21:05 »
I reckon that's your answer! ^^:D
The fans are sucking in really hot air so heat transfer will be not as efficient as normal. Are you using the AirCon? This usually drops the engine temperature by several degrees :y
danzigfan
« Reply #3 on: 10 July 2011, 14:36:53 »
Yes, A/C on and it does drop temp for few degrees  but I was afraid it will rise even more. Thanks
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #4 on: 10 July 2011, 15:16:36 »
Your picture shows a temperature well within the normal range.  If your rad is hot and both fans are working, I wouldn't worry about it.
I feel like a military academy. Bits of me keep passing out.
danzigfan
« Reply #5 on: 10 July 2011, 15:23:04 »
You know, many years ago I had something that was trying to be a car - never was or will be one. Peugeot, constantly tending to overheat. That's why I'm so easily irritated by temp gayge rising. Thank you too
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #6 on: 10 July 2011, 15:39:22 »
Driving mine 2 weeks ago
31 degree's outside
Motorway / fast roads
Air con switched on
Temp sat between 97 and 99 degree's
I believe the fan on the V6 is a two stage fan which comes in around 97 degree's then full power at around 99 degree's  :-/
I'd keep a eye on the coolant level but other then that, don't worry  ;) ;)
danzigfan
« Reply #7 on: 10 July 2011, 15:53:15 »
Thanks, so I'll just keep an eye on temp if that's the way it is :y
Page created in 0.03 seconds with 20 queries.
