Author Topic: Coolant system cleanout .......  (Read 1508 times)
I_want_an_Omega
« on: 12 July 2011, 08:57:23 »
Want to give the coolant system a good cleanout. So far have drained the system a couple of times and run the car. The coolant is now pretty much just water - and fairly clean.
I've read about using some low suds detergent - could anyone suggest an exact sort to use as I have visions of never ending suds from the header tank!
In anticipation - Rob
I_want_an_Omega
Re: Coolant system cleanout .......
« Reply #2 on: 12 July 2011, 09:07:53 »
Thanks - looks ideal, but I was hoping that there was something that I could pop out @ lunchtime and buy in Tesco.
If not then I'll send off for this stuff.
« Reply #3 on: 12 July 2011, 09:17:35 »
"Bold" or any other "low suds" detergent can be used
I_want_an_Omega
« Reply #4 on: 12 July 2011, 09:29:39 »
So that's a bottle of Bold in the header tank then.
Is all Bold low suds, or is there a specific low suds Bold that I should look out for?
How long would you leave it in there before flushing that out. I only do a very small mileage so was thinking of a week or so?
Thanks
« Reply #5 on: 12 July 2011, 10:14:21 »
Use the liquid gel type rather than powder - very popular with housewives these days, so Im told  :D. It just needs to be for automatic washing machines rather than handwash type. Which I would guess almost all of them are these days.
I wouldnt put the contents of the whole bottle in there personally, I could be wrong but it seems like too much to me.
I used the stuff for the final flushes after having to change the oil cooler, and a bottle did several flushes.
I would flush it after a couple of hours running.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #6 on: 12 July 2011, 14:59:47 »
Am I right in thinking that Bold, as used in a washing machine is a dual type that contains a fabric softener too?
If that is right then it will coat the internals and play havoc as it did when I tried it in my central heating system instead of using the right stuff.
best way I have found is to use an eggcup full of the liquid general purpose detergent used in Karcher pressure washers or I have also used the diluted fluid used in a Vax carpet shampooer with brill results, and then a good flush through with plain water.
Both are low foaming anyway. :y
I_want_an_Omega
« Reply #7 on: 12 July 2011, 18:08:07 »
After totally confusing myself I have ordered the Forte stuff - just have to wait a few days for it to arrive  :y
I've done two more flushes today and things are looking a lot better. However, by opening the header tank lid and draining the rad via the drain plug I can only get out about 4 litres out - so any ideas on getting an other litre out would be welcome. Once I've finished flushing and have clean water I can then fillup with 5L of red coolant and then top up with water.
Hope that all makes sense.
Thanks
Big_Al
« Reply #8 on: 12 July 2011, 18:45:34 »
bit late with this reply prehaps but . . 2 dishwasher tablets disolved in water first - then added.
Leave in for a day or two.
  Works a treat especially if any oily deposits to disperse.
several clean water  flush outs after.    Sorted , used this myself many times 8-) 8-)
Forte is the stuff though.   But Around 40 quid I think.  :( :(
« Last Edit: 12 July 2011, 18:53:25 by Big_Al »
I_want_an_Omega
« Reply #9 on: 12 July 2011, 19:47:54 »
Forte is the stuff though.   But Around 40 quid I think:( :(
£16.50 from fleabay, but the dishwasher tablet option seems sensible also - thanks for that.
Big_Al
« Reply #10 on: 12 July 2011, 20:00:45 »
sorry don't know where I got £40 from -  maybe I was allowing for this weeks inflation increase ;D ;D ;D ;D ;D ;D ;D ;D ;D
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #11 on: 13 July 2011, 11:06:16 »
Thanks for these posts guys, I'm getting over heated and hoping a good flush will help!?  :-/
