Author Topic: manual conversion.. help  (Read 1075 times)
« on: 15 July 2011, 20:52:35 »
from the gearbox (I think its r25)
I have this flywheel
this pressure plate and bearing
problem is new pressure plate and bearing (old one not usable) costs approx 450 £ :o >:(
and although flywheel seems usable with some skimming I cant trust it for long term.. its from LUK and in case of change I need to pay another 500 £ minimum :o :( >:(
so checking this thread
http://www.omegaowners.com/forum/YaBB.pl?num=1161590849/6
front wheel flywheels can also be used and they are cheaper..
question is, which one must be choosed for long term, cars health and economy optimised.. any info/opinion appreciated..
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: manual conversion.. help
« Reply #1 on: 15 July 2011, 21:27:54 »
PM Matchless, he's the expert.
I like red cars
Omegatoy
  • UK
« Reply #2 on: 15 July 2011, 21:34:39 »
any solid flywheel should last the life of the car i would have thought Cem? so longevity isnt really an issue,
for what its worth the 2.5 v6 vectra clutch as far as i can gather is pretty long lasting in normal use, but if this is a one time only job think i would look into an uprated clutch material if its available there, then you wouldnt have to do the job again!!!
just one thought though, pleae do not forget to fit a spigot bush bearing in the end of the crank, or your manual box wont last a 1000kilometers!!! :y
« Reply #3 on: 15 July 2011, 21:48:08 »
I will , thanks :y
« Reply #4 on: 15 July 2011, 21:53:34 »
1.any solid flywheel should last the life of the car i would have thought Cem? so longevity isnt really an issue,
, but if this is a one time only job think i would look into an 2.uprated clutch material if its available there, then you wouldnt have to do the job again!!!
just one thought though, pleae 3.do not forget to fit a spigot bush bearing in the end of the crank, or your manual box wont last a 1000kilometers!!! :y
1. thats good news which makes me feel better.. so I dont have to worry about future flywheel expenses.. :y
2. Even the normal items not that easy to find, so uprated clutch seems a bit far.. I need to order from abroad which needs more time.. :-/
3.Thanks for warning.. this advice I'll definitely listen :y :y :)
« Reply #5 on: 15 July 2011, 23:40:05 »
for those interested, I found this link which says vectra flywheels and clutch can be used although there is some 5 mm difference..
also said in the above thread ;D
http://retrorides.proboards.com/index.cgi?board=readersrides&action=print&thread=94677
« Last Edit: 15 July 2011, 23:45:05 by cem_devecioglu »
