Author Topic: Car intermittentley not starting  (Read 2155 times)
megaomega123
« on: 17 July 2011, 14:49:44 »
A few times today, the car has not started. Leave it for a while and then starts no problem.
There is no noise when I turn the key and engine does not turn over. Battery is good and running is also good. Did it about 6 months ago in the snow and then today after driving through very deep water.
I am suspecting the starter motor or could just be the connections and could be related to water ingress.
Any ideas welcome as I don't want to be left stranded  :y
Alex W
    • 2000W Facelift 2.5V6 Elit
Re: Car intermittentley not starting
« Reply #1 on: 17 July 2011, 14:58:12 »
Sounds like the infamous crank sensor to me.
Alex W
« Reply #2 on: 17 July 2011, 14:58:58 »
Forget that, it turns over but won't fire if the crank sensor has gone.
megaomega123
« Reply #3 on: 17 July 2011, 15:00:55 »
Was my 1st thought until I just read the other crank thread.
No turn over, absolutely nothing when key is turned.
Alex W
« Reply #4 on: 17 July 2011, 15:50:18 »
Have you checked for fault codes?
megaomega123
« Reply #5 on: 17 July 2011, 15:56:01 »
No EML light at any point so not bothered with codes.
Alex W
« Reply #6 on: 17 July 2011, 16:20:25 »
I am admittedly one of the least experienced mechanics on here but I would suggest you perform a a paperclip test.
megaomega123
« Reply #7 on: 17 July 2011, 16:39:58 »
Just done paperclip test and no codes stored.
tango
  • brum
« Reply #8 on: 17 July 2011, 17:07:18 »
is it manual or auto
might sound silly but misses came in the other day saying the car wont start had a look and it wasnt pushed into park fully
megaomega123
« Reply #9 on: 17 July 2011, 17:34:00 »
Manual.  :y
megaomega123
« Reply #10 on: 17 July 2011, 17:34:39 »
Is water ingress possible on the starter motor?
Alex W
« Reply #11 on: 17 July 2011, 18:16:45 »
Immobiliser fault perhaps? I have no suggestions about how to find out but you would expect some noise if it were starter motor or battery problems.
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #12 on: 17 July 2011, 18:56:46 »
What dash lights are lit at key position 2 (the one before you start) ?
Those are my principles, if you don't like them I have others.
megaomega123
« Reply #13 on: 17 July 2011, 19:42:38 »
All the ones that should be and then all the right ones go out after self check, then no lights when engine running.
Page created in 0.033 seconds with 20 queries.
