Author Topic: Is it compatible?  (Read 2260 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Is it compatible?
« on: 19 July 2011, 18:29:07 »
Will my 3.0 injectors fit in place of the 2.6 injectors on the inlet manifold?
TIA :y
AKA - Mr Bracket
Re: Is it compatible?
« Reply #1 on: 19 July 2011, 23:58:43 »
They will physically fit. I can't remember if the spec. is the same. 2.6/3.2 injectors run at higher pressure, IIRC, so likely different flow rates, and the fuel pressure regulator will be different.
blackviper90210
« Reply #2 on: 20 July 2011, 07:31:34 »
Cheers Kevin. I'm after an inlet manifold and one is being offered for a fiver on here. Just needed to know if my injectors will slot straight in place of the 2.6 one's?
Ref the fuel pressure reg, is that part of the manifold?
AKA - Mr Bracket
MutantCav
  • Gainsborough
« Reply #3 on: 20 July 2011, 07:51:36 »
Its on the fuel rail :y
blackviper90210
« Reply #4 on: 20 July 2011, 08:13:27 »
Right, ok.
So really that doesn't make any difference then?
I can take the 2.6 injectors out, replace with my 3.0 ones and put it back on again?
TIA
AKA - Mr Bracket
« Reply #5 on: 20 July 2011, 08:23:28 »
Right, ok.
TIA
MutantCav
  • Gainsborough
« Reply #6 on: 20 July 2011, 08:26:29 »
And you can just swap the fuel rail over if needed :y
blackviper90210
« Reply #7 on: 20 July 2011, 08:33:55 »
Sound as a pound, cheers guys!   :y
AKA - Mr Bracket
« Reply #8 on: 20 July 2011, 09:51:54 »
Beware that the 2.6/2.5 manifolds are different to the 3.0/3.2 ones, though. The intake tracts are very slightly narrower. If possible, find a manifold from a 3.0 or 3.2.
blackviper90210
« Reply #9 on: 20 July 2011, 10:53:25 »
Oh bugger.  :'(
At least I've found out now, cheers Kevin.
I'll let the seller know now, as he's holding it for me!  :y
AKA - Mr Bracket
« Reply #10 on: 20 July 2011, 11:05:25 »
Difference is negligible
« Reply #11 on: 20 July 2011, 12:18:12 »
Perhaps, but you'll have a step between the 2.5 intake manifold and the 3.0 divider, which is a bad thing. GM wouldn't have produced 2 different parts with a "negligible" difference unless there was a good reason.
FWIW, if the reason for changing the manifold is just to eliminate straw nozzles from the LPG setup, I'd not bother at all, if it's now running well.
blackviper90210
« Reply #12 on: 20 July 2011, 14:07:39 »
It's deff running better now James did his magic on it. iirc, he suggested changing and re-routing the rest of the pipework and then to set the LPG injectors into the manifold.
So do you believe, other than renewing the rest of the pipework, leave it well alone? A case of it's not broken now, don't fix it?
Just waiting to see if my petrol consumption will slow down as I was going through 1/4 tank petrol every 2 weeks roughly, whilst running on LPG.  :-/
AKA - Mr Bracket
« Reply #13 on: 20 July 2011, 14:15:27 »
Well, it's a case that if I were converting it from scratch I'd fit nozzles into the manifold rather than to use straws, as the latter is a little unsightly and really only saves time for the installer.
Having said that, if it now runs pretty much as well on gas as it does on petrol that's all you will ever achieve, so if it 'ain't broke?
Of course, I haven't seen the car in question. I just wouldn't swap straws for nozzles on a car that was otherwise running quite happily on LPG with a satisfactory install. :-/
blackviper90210
« Reply #14 on: 20 July 2011, 14:25:31 »
Fair enough.
Not being a mechanic and picking bits up as I go along, I listen to the advice I get from you guys & girls who do know.
Thats why I end up asking stupid questions even on the simplest things!  :)
AKA - Mr Bracket
