Author Topic: horrible smell passenger side  (Read 2470 times)
tomoco
  • leicester
« on: 20 July 2011, 21:10:35 »
just fitted a new crank sensor. noticed when i was under the oil filter i could see drips of something yellowish. comming from the top of engine below the skuttle Which was off. Had a horrible burnt smell since the aircon was gassed up. mixture of old oil / and engine felt very hot on that side.
The liquid smelt like gearbox fluid but not pink
Aircon fans not kicking in now at all
checked water level. seemed a bit low just at centre panel of expansion tank. noticed seal on top of lid knackered fitted replacement lid
mark :-?
« Last Edit: 20 July 2011, 21:25:17 by tomoco »
Re: horrible smell passenger side
« Reply #1 on: 21 July 2011, 01:52:01 »
Odd, any pics?
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 21 July 2011, 05:52:27 »
Someone lifted their bumcheek? :D ;D
Seriously now....
You need to wash off the engine and then have a looky after a hot run to see where the problem originates.
Get back to us then and maybe someone will know how to help.  :y
« Last Edit: 21 July 2011, 05:54:15 by its.ray »
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #3 on: 21 July 2011, 19:03:58 »
Any mechanical symptoms?
Omega 2.6 V6 Elite in Shiny Black
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 21 July 2011, 19:11:37 »
I occasionally have a bad smell on the passenger side, I cure it by asking the Mrs to get out the car
Alex W
    • 2000W Facelift 2.5V6 Elit
« Reply #5 on: 21 July 2011, 20:37:42 »
;D ;D ;D ;D ;D ;D
tomoco
  • leicester
« Reply #6 on: 22 July 2011, 13:50:01 »
Think its something to do with the cooling chaps  ;D
It dont smell in the car just engine bay. Car seems to run very hot on that side. just done crank sensor because it failed on me. Now the cooling fans arent kicking in see (cooling fans post)
she 's starting to let me down now.  :'(
« Last Edit: 22 July 2011, 13:51:59 by tomoco »
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #7 on: 22 July 2011, 20:20:57 »
could the fluid be dye from aircon?
tomoco
  • leicester
« Reply #8 on: 23 July 2011, 22:32:15 »
could be  aircon dont work anymore :'(
although not sure what aircon fliud smells like when its very hot... smells similar to fully synthetic gearbox fliud to me
mark
old git
  • Shrewsbury
« Reply #9 on: 24 July 2011, 01:39:43 »
you should be able to press the filling valve open (i think it's just like a tyre valve it was on the senator see if any gas comes out)at least  it will show if you still have gas in system or if it leeked out but there maybe a cut out on low preasure that stops the compressor clutch engaging so the compressor don't knacker.
Page created in 0.034 seconds with 20 queries.
