Author Topic: Rear multiram still not working  (Read 4546 times)
Re: Rear multiram still not working
« Reply #15 on: 25 September 2007, 00:14:40 »
Does the ECU report any fault codes? If the actuator and plumbing are OK it looks like the electrical feed to the actuator - but it would raise a code if the ECU was seeing open / short circuit from its' end  :-/
Codes 73 and 74 are stored. Both are Maf voltage out of tolerance codes.
If I unplug the ram, I get an EML light, plug it back in, it goes away. So there is some form of connection there..
« Reply #16 on: 25 September 2007, 18:39:56 »
No air intake leaks?
« Reply #17 on: 25 September 2007, 18:49:39 »
You mean around plenum, bagpipes, inlet manifold etc? No obvious ones, and idle is fine...
« Reply #18 on: 25 September 2007, 18:56:54 »
Oh dear :(
Best bring it over for a tech2 session, we'll see what MAF is doing...
Need to fix the errors that ECU can see (the error handling generally isn't tested that well, so possible with this error, the rear multiram doesn't work).
« Reply #19 on: 25 September 2007, 19:44:11 »
Ah Ha... Maybe some sort of limp-home strategy has disabled it... Only explanation if the ECU can still detect its' disconnection I guess.
« Reply #20 on: 27 September 2007, 19:50:21 »
Jaime, you around tomorrow anytime? Day/Eve?
I'm going to be in brackley...
« Reply #21 on: 27 September 2007, 19:54:30 »
Don't know. Defo not during day, not sure on evening yet. Sorry can't give a defo yes/no
« Reply #22 on: 27 September 2007, 20:00:01 »
No problems, I'm going to be over there anyway.
It's totally non urgent, I can come back anytime..
Aivaras
« Reply #23 on: 26 July 2011, 09:49:09 »
what's new? maybe you have resolved this problem then?
« Reply #24 on: 26 July 2011, 10:34:03 »
It was nearly 4 years ago. I've lost count of how many Omegas JamesV6CDX has had since then. ;D
