Author Topic: Headlamp lense cleaning  (Read 4831 times)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Headlamp lense cleaning
« Reply #15 on: 29 July 2011, 18:25:48 »
Glad this question was asked, seems like good results. I was going to source new headlights  :-[ but will try the T-cut method later. Cheers fellas, saved me some cash :y :y
When you do try it, get back and let us know how you got on!!  :y
 :) :) Well i'll be buggered, works a treat. Gave them 2 going overs and come up excellent. Many thanks for the tip fellas :y  Thinking about popping down the road tonight and doing just one lamp on each of my neighbours cars, maybe a vertical line  ;D ;D ::)
« Last Edit: 29 July 2011, 18:26:18 by sticka_v8_init »
Those are my principles, if you don't like them I have others.
rewdoo
  • Harrogate
« Reply #16 on: 29 July 2011, 18:56:37 »
Hi had the same problem and found that UPVC cleaner worked on mine. It is around £6 a bottle and does take a bid of work thought. It cleared the headlights and was well worth the time. Andy
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #17 on: 29 July 2011, 22:04:48 »
I've found the best way to bring up miggy's lenses like glass is with a product called Meguiars Plast RX clear plastic cleaner & polish  needs a good quality yellow duster and plenty of ebow grease,but well worth the effort
Hannah Judes Dad
    • the misses round the bend
« Reply #18 on: 31 July 2011, 15:05:48 »
Don't laugh when I tell you this but toothpaste also works on headlights !
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #19 on: 31 July 2011, 15:10:58 »
Lights must looking mint after that!  :D :D :y
Hannah Judes Dad
« Reply #20 on: 01 August 2011, 15:21:32 »
hopefully you won't get a brush with the law  :-[
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #21 on: 01 August 2011, 16:24:28 »
Does that give you a 5000k "whiteness"??  ;D
AKA - Mr Bracket
Hannah Judes Dad
« Reply #22 on: 01 August 2011, 17:15:48 »
This thread is making me look a little dim
ninjapirate
  • dummer. hants.
« Reply #23 on: 01 August 2011, 18:05:18 »
i can clearly see where your going with this toothpaste idea....
that really was bad, even for me! :-X :-X ;D
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #24 on: 01 August 2011, 20:32:49 »
So can i, reckon he's on the Crest of a wave with this idea. My mate Mac cleans his with Sensodyne....he swears they fill in all the small indents in the plastic hence the shine.
Greenbay packer
  • North Devon
« Reply #25 on: 01 August 2011, 20:59:21 »
Fine wet 'n dry is ok (~1000 - 1200 grit), followed by cutting compound, then a final buffing up with T cut, brasso or something similar.  :y
My headlamp lenses were in a dreadful state so I used very fine wet and dry, well lubricated) followed by Meguiars PlastRx (from Fleabay) - it worked a treat and has lasted well.  Try on a small area that is not prominent first.  Be careful if using fast rotating power tools to buff up your lenses - I have heard it is possible to melt lenses with these!
