Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: How Many Hours to do a Auto to Manual Conversion??  (Read 7205 times)
2woody
  • Northumberland
Re: How Many Hours to do a Auto to Manual Conversion??
« Reply #60 on: 03 August 2011, 19:39:14 »
also.....
gearchange extension ( full - including mounting bracket to transmission tunnel with rubbers )
rubber cover for change extension with clips
exhaust support bracket
connector for reversing lights
downpipe nuts and gaskets
clutch pipes ( not of the make-your-own variety )
serek
  • huntingdon
    • 3.2 mv6
« Reply #61 on: 03 August 2011, 19:49:44 »
One thing that`s,  often overlooked is the spigot bearing for the crank, make sure you have one of those, in fact off the top of my head here`s a quick list of things you will need.
Gearbox with slave cylinder
Gearbox crossmember
Front half of propshaft
Spigot bearing
Clutch and flywheel (a good opportunity to fit a lightened flywheel  ;) )
Flywheel bolts
Flywheel locking tool , easy to make yourself.
Pedal box
Copper/nickel brake pipe
brake pipe flaring tool
Gearstick
Rubber gator and adaptor plate for gear stick ( rivets to the transmission tunnel)
Silver or wood surround
Leather surround
If you have cruise fitted then you will want a clutch switch for the cruise loom
If it was me I would also use the fuel,injection loom from a manual car too and remove the auto loom and ECU.
I`d also fit two new propshaft rubber couplings and a new propshaft centre bearing carrier too as these can perish.
why you need flaring tool??
surround panel on FL cars ane same on auto and manual cars :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #62 on: 03 August 2011, 22:39:31 »
Gearbox crossmember
Spigot bearing
Flywheel bolts
Pedal box
Gearstick
Leather surround
The clutch is hydraulic so you will need to make up a pipe from the master cylinder to the gearbox, unless you use one from a donor car.
Mr Gav
  • Leeds
« Reply #63 on: 03 August 2011, 22:42:42 »
And then I`ve just read 2woody`s post about clutch pipes  :-[ oops
serek
  • huntingdon
    • 3.2 mv6
« Reply #64 on: 03 August 2011, 22:46:06 »
I done few conversion , and always use all parts from doner car  :)
Pages: 1 2 3 4 [5]  All   Go Up
