Author Topic: Estimate of cost  (Read 3272 times)
bigdods
  • Brackley
Re: Estimate of cost
« Reply #15 on: 07 August 2011, 14:36:59 »
Happened to my old 2.5 cdx about 5 miles after I sold it. Mind you it had been making noises before that for about 100 miles and water was weeping out of the front.
Guy that bought it made it to the m40 from brackley then the waterpump just expired and let all the water out.
Lucky that its pretty cheap to replace, I now have mine replaced with every cambelt change just to be sure.
philsteward
  • Leeds, West Yorkshire
    • 2001 2.2CDX Estate LPG
« Reply #16 on: 07 August 2011, 14:52:57 »
Exactly the same happened on mine 2months before I bought it to the previous owner. Got the AA report, and the bill from the garage. Labour came in at £120 he had the cam belt and tensioner done at the same time though, but that should not effect labour as all has to be removed to do water pump anyway.
Hope that helps
« Reply #17 on: 07 August 2011, 14:57:49 »
... but that should not effect labour as all has to be removed to do water pump anyway.
Hope that helps
Not on a V6  ;) ;)
philsteward
« Reply #18 on: 07 August 2011, 15:01:24 »
Hope that helps
Not on a V6  ;) ;)
Never thought about it being a differbt engine, but it is a 2.6 so think I am correct still?!!
« Reply #19 on: 07 August 2011, 15:06:41 »
Hope that helps
Not on a V6  ;) ;)
On V6, Waterpump is aux belt driven, not cambelt driven.
You don't need to remove cambelt to change the water pump  :y
« Reply #20 on: 07 August 2011, 15:08:28 »
........and the 2.6 is a v6. :y
philsteward
« Reply #21 on: 07 August 2011, 15:14:54 »
Oh I shall shut up then!  :'(
« Reply #22 on: 07 August 2011, 15:19:27 »
No need to shut up mate.we were all in a position of not knowing these things at some point. ;)
« Last Edit: 07 August 2011, 15:21:19 by albitz »
« Reply #23 on: 07 August 2011, 15:24:31 »
rough breakdown:
2.0/2.2 -> 4 pots (basically same engine with just few differences)
2.2 DTi - 4 pot Chain driven engines, not belt.
2.5TD - BMW Lump, Straight 6
2.5/2.6/3.0/3.2 - V6 Lumps, largely the same, later .6 and 2.'s tad different but basically same engine
 :y :y
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #24 on: 07 August 2011, 16:39:10 »
Thanks guys. A bit of soul searching to do I think before I make a final decision!!!  :(
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #25 on: 07 August 2011, 18:11:09 »
use can change the water pump on a 2.6 v6 without removing cambelt  :y
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #26 on: 08 August 2011, 09:06:27 »
Yes you can but the front cover has to come off first, so muti ram has to come out and aux belt removed aswell :y
noel
  • frome somerset
« Reply #27 on: 08 August 2011, 21:11:58 »
Page created in 0.035 seconds with 20 queries.
