Author Topic: EML light  (Read 1699 times)
moog
  • moreton in marsh
EML light
« on: 15 August 2011, 20:06:40 »
Hi for a few weeks at times on first start in the morning my omega sounds and runs like its only running on 4 or 5 cylinders. After a couple of mins or a few 100 yrds its fine. However this morning the eml light came on with the same rough running, 2 mins later all is fine and light is out. Started perfect tonight with no light or any other problems. I have a long trip to brixham in it on friday and i'd rather it didn't leave me stranded on the hard shoulder, any ideas anyone? :-/
johnnycboy
  • Colchester
Re: EML light
« Reply #1 on: 15 August 2011, 20:23:46 »
Pedal trick to see if there are any codes  :question
Re: EML light
« Reply #2 on: 15 August 2011, 20:25:57 »
As johnnycboy says, pedal trick it and post up the results (See FAQ/Maintenence Guides on how to do this)
moog
  • moreton in marsh
Re: EML light
« Reply #3 on: 15 August 2011, 20:36:28 »
10 3 10 10 random misfire.
Re: EML light
« Reply #4 on: 15 August 2011, 20:55:22 »
seems ignition related, checking coils and plugs may give an idea..
condition of sparks may say something so you can change the items positions and identify..
« Last Edit: 15 August 2011, 20:59:59 by cem_devecioglu »
moog
  • moreton in marsh
Re: EML light
« Reply #5 on: 15 August 2011, 21:01:42 »
Thanks all of you. :y
Re: EML light
« Reply #6 on: 15 August 2011, 21:13:44 »
Was that the only code? Normally there are others as well with that code :y
moog
  • moreton in marsh
Re: EML light
« Reply #7 on: 16 August 2011, 20:24:15 »
If i keep going after the 10, 3, 10, 10 it goes 10, 3, 10, 2.
Re: EML light
« Reply #8 on: 16 August 2011, 20:30:10 »
0302 ......... mis-fire on cylinder 2  :y
Plug? Coil pack?
moog
  • moreton in marsh
Re: EML light
« Reply #9 on: 16 August 2011, 20:35:50 »
Thanks, :y ordered a set of plugs yesterday so fingers crossed.
Re: EML light
« Reply #10 on: 16 August 2011, 21:08:52 »
And what after that?
moog
  • moreton in marsh
Re: EML light
« Reply #11 on: 16 August 2011, 21:23:01 »
Ill find out tomorrow now. How many times do you have to keep going or does it just stop when its listed all faults?  :-?
Re: EML light
« Reply #12 on: 16 August 2011, 21:38:43 »
Each code will flash 3 times, once all codes displayed, it will stop flashing.
Page created in 0.028 seconds with 20 queries.
