Author Topic: auto gearbox problem  (Read 2144 times)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« on: 09 August 2011, 20:57:43 »
seem to have developed a whistle/whining noise,but more worrying is when accelorating hard (ie. kick down)it revs and drives upto 5000 revs but wont change gear (its as if its picking a neutral) but if i let the revs drop to 3000 revs it will change.
the whistle / whine noise seems to be intermitent.but not sure where to start looking for this problem.
is it possible the ATF level in the gearbox could cause this ???. any help thanks in advance. :(
  • Online Online
Re: auto gearbox problem
« Reply #1 on: 09 August 2011, 21:08:51 »
is it possible the ATF level in the gearbox could cause this ???. .. :(
At least checking the level is a good starting point. A fluid change won't do any harm.  :y :y
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« Reply #2 on: 09 August 2011, 21:36:49 »
Hi,
Are you getting any warning lights?
Have you tried the paperclip test to see if there are any fault codes stored?
I get the same symptoms when my car goes into limp home mode.
J
Things to do: Air Con still leaking
noel
  • frome somerset
« Reply #3 on: 09 August 2011, 21:39:43 »
no dash warnings and nothing showing on my code reader :(
twiglet
  • Norwich, Norfolk
« Reply #4 on: 09 August 2011, 23:58:35 »
I've got a sweet gearbox from a 2003 2.6 V6 taking up space in my garage... Not wanting much for it either...  :y
« Reply #5 on: 10 August 2011, 00:26:23 »
Paper clip and pedal test will do no harm at all, but be advised these methods only read the engine ecu.
They do not read the gear box ecu.
However if it's wineing then surely thats mechanical...? Fluid check/service... Possibly check the solenoids activate correctly via tech 2. Other than that there's not much to do with it other than replace. Which is not as bad as it sounds, auto boxes change Hands on here for fair money usually, then a half decent mech to swap in the new one. My local man will do it for £300 odd for instance.
noel
  • frome somerset
« Reply #6 on: 10 August 2011, 19:10:01 »
cant do paper clip test as its a 2.6 v6.
but did pedal trick and showed no codes  >:(
noel
  • frome somerset
« Reply #7 on: 18 August 2011, 08:24:15 »
well gearbox packed up whilst on holiday car was recovered to local vaixhall stealership who did diagnostic test on gearbox which showed torque convertor / internal gearbox problem so will be replacing gearbox when i get her home (looking forward to that) :( :(
« Reply #8 on: 18 August 2011, 13:18:51 »
Only difficulty in changing autobox is its weight - ideally 2 people plus good trolley jack to lower/raise box.  Unbolt torque converter so that it comes out with box.  You'll need to drop both cats (requires long extension & 16mm socket to undo cats from manifold - plenty of plusgas helps).  Allow 3-4 hours with tea breaks to do.  :y
noel
  • frome somerset
« Reply #9 on: 18 August 2011, 14:42:14 »
thanks for the info lets hope ot all goes smoothly as i am not paying stealers £85 an hour and hopefully i wi'l do q better job ??  :-/ :y
noel
  • frome somerset
« Reply #10 on: 20 August 2011, 21:42:44 »
big thank you to RobseyMV6 for the gearbox and extras and of course the handy hint for removal and refitting  :y :y
