Author Topic: Rear Diff Oil  (Read 1846 times)
Radar
  • Berkshire
    • Elite 2.5 Auto
Rear Diff Oil
« on: 22 August 2011, 22:05:29 »
Can anyone recommend one which has a long enough plastic tube built in for easy top up?
(Non LSD)
Thanks
twiglet
  • Norwich, Norfolk
Re: Rear Diff Oil
« Reply #1 on: 22 August 2011, 22:07:27 »
You only need 3-4 inches of tube max, as you can get the bottle pretty close to the file hole.  :y
Re: Rear Diff Oil
« Reply #2 on: 22 August 2011, 22:07:50 »
Any old EP90 hypoid gear oil will do. I guess a trip to the local motor factors to check the spouts is the best plan. :-/
Re: Rear Diff Oil
« Reply #3 on: 22 August 2011, 22:10:46 »
turned the car nearly 50 degrees to empty ;D
but worth , as the old oil was no different than mud..
Omega_Dan
Re: Rear Diff Oil
« Reply #4 on: 22 August 2011, 22:16:36 »
Not trying to hi-jack the thread but is it a simple job to top up. i have a very small oil leak on mine and want to top it up to be on the safe side.
Re: Rear Diff Oil
« Reply #5 on: 22 August 2011, 22:20:45 »
I suppose I should have a look at the level on mine too. My car won't rust around the floor pan around the diff/prop  ::) ::)
twiglet
  • Norwich, Norfolk
Re: Rear Diff Oil
« Reply #6 on: 22 August 2011, 22:21:11 »
You can just top it up Dan, or you can do a complete fluid change if you want. Have a look here.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1161520937
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Rear Diff Oil
« Reply #7 on: 22 August 2011, 22:21:44 »
I went to the stealers and the chap said it does not come with a tube and couldn't check since it had to come from another dealer :'(
Seen some on halfords - is gl5 more suitable than gl4?
twiglet
  • Norwich, Norfolk
Re: Rear Diff Oil
« Reply #8 on: 22 August 2011, 22:22:06 »
 ;D ;D I don't think many of em will Andy!  ::)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Rear Diff Oil
« Reply #9 on: 22 August 2011, 22:25:00 »
Looks straightforward - jack up rear drivers side and locate hex bolt on side of diff. Undo the bolt,  top up and tighten bolt again.
twiglet
  • Norwich, Norfolk
Re: Rear Diff Oil
« Reply #10 on: 22 August 2011, 22:25:36 »
When I did my diff and gearbox, I used Opie Oils. Check out there link at the top of the 'parts for sale' section.
They offer discounts to OOFers and the oil was delivered next day! Spot on!  :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Rear Diff Oil
« Reply #11 on: 22 August 2011, 22:31:54 »
I must be thick 'cos i looked on their site already but wasn't sure which one (mineral,synthetice etc..)- can you tell me which one you used or do a linky? please
Re: Rear Diff Oil
« Reply #12 on: 22 August 2011, 22:54:02 »
Yes, GL5 is better for diffs, if I recall correctly. GL4 is for certain gearboxes where some of the more aggressive additives in GL5 oils would attack the metal bushes.  No such problems putting it in a diff.
twiglet
  • Norwich, Norfolk
Re: Rear Diff Oil
« Reply #13 on: 22 August 2011, 23:49:05 »
http://www.opieoils.co.uk/p-972-fuchs-titan-gear-hyp-90-hypoid-gear-oil-gl5-80w-90.aspx  :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Rear Diff Oil
« Reply #14 on: 23 August 2011, 09:11:25 »
Thankyou guys :y
