Author Topic: Rear Shocks - Top Bolt  (Read 2234 times)
« on: 16 August 2011, 16:42:36 »
What mm is the top bolt for the rear shock? - Any tips for removing it?
As I'm changing the rear springs soon, I'm going to change the shock too. When I attempted this last time I could not get any grip on the very small top stock bolt. Its something like 4mm?
I put an adjustable on it, but it always slipped off  :(
Varche
  • middle of Andalucia
    • Golf Estate
Re: Rear Shocks - Top Bolt
« Reply #1 on: 16 August 2011, 16:52:43 »
I had the same problem.
In the end what worked for me was to grip the top washer with a pair of curved jaw mole grips. I guess the washer was stuck/rusted to the shocker.
Edit top nut is 6 mm, well it is on my s/l shocks
« Last Edit: 16 August 2011, 16:57:17 by olive »
« Reply #2 on: 16 August 2011, 17:00:51 »
Easier inside the car with seats down
« Reply #3 on: 16 August 2011, 17:07:05 »
some plonker put an LPG tank in my boot  ::)
I put mole grips on it too last time, again slipped off. If its 6mm I'll hunt around for a spanner that size  :)
« Reply #4 on: 16 August 2011, 18:18:07 »
Iirc.... :-/
Had similar issue on TB's car, so used mole grips on the plastic gater to hold the shaft still from the wheel arch, while an assistant used an air ratchet on the bigger top securing nut(nyloc jobby is it?) from inside the boot. It buggered the gater, but if your fitting new shocks who cares. :)
Maybe nip round to The Groomer for some.... "assistance"  ;)
  • Auckland
    • Mazda MPV
« Reply #5 on: 16 August 2011, 18:50:51 »
Cheap adjustable spanners seem to be designed to fail. Only useful as paperweights in my experience.
I have a Bahco adjustable spanner which had no problem holding the top mount on the last 3 occasions I changed VX rear shock absorbers :y
« Last Edit: 16 August 2011, 18:51:17 by andyh »
« Reply #6 on: 16 August 2011, 20:08:14 »
Thanks Chaps  :y
Not looking forward to that "Payment Stage" by The Groomer  ;D
« Reply #7 on: 16 August 2011, 20:17:35 »
Thanks Chaps  :y
Oi, my name isn't Geoff....
« Reply #8 on: 16 August 2011, 21:04:06 »
Thanks Chaps  :y
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D PMSL :D :D :D :D :D :D :D
« Reply #9 on: 16 August 2011, 22:27:23 »
Thanks Chaps  :y
Geofreeeeey..... :-*
 ;D
« Reply #10 on: 17 August 2011, 07:35:02 »
Such children!
« Reply #11 on: 17 August 2011, 14:43:23 »
Iirc.... :-/
Oh dear ....I see. :-X
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 17 August 2011, 20:31:42 »
The nut is no problem, you have to hold the rod which has two flats. Last time I struggled, I unbolted my vice from the bench & used that in a "death grip", that showed it who was boss. (Actually the rod snapped, so wouldn't have come undone anyway).  Good job I was renewing the shock.
« Reply #13 on: 04 September 2011, 10:17:57 »
I now have the same problem with my car.Just went to undo my o/s shock and someone has been there before me, the top part which had 2 flats is all chewed up. Tried mole grips on the gaiter and on the damping rod itself but the rod still turns when I turn the spanner on the top.Im at work, so tools are a bit limited, will probably leave it until tomorrow - at home in daylight, but having said that Im still not sure what I can do there, apart from having several different shapes/sizes of mole grips. One of which might just hold the rod better. :-/ :(
« Reply #14 on: 04 September 2011, 11:22:40 »
As you`re replacing them use a 4" grinder :y
