Author Topic: HID Replacement  (Read 1107 times)
richdrury
  • mildenhall, suffolk
    • 2000 2.5 v6 cdx facelift
HID Replacement
« on: 06 September 2011, 18:19:14 »
Hey all, i am looking at replacing my hid bulbs soon and wondered if there was any special procedure to follow as ive never done these before?
thanks in advance,
Re: HID Replacement
« Reply #1 on: 06 September 2011, 22:05:30 »
Dead easy mate - just leave car for about 20 mins from switching off before swapping HIDs  :y
richdrury
Re: HID Replacement
« Reply #2 on: 07 September 2011, 07:01:35 »
Oh ok, at the risk of sounding stupid i thought that there may be a shock risk from the ballast boxes, but if its that easy ill be doing it myself,
Re: HID Replacement
« Reply #3 on: 07 September 2011, 22:02:07 »
Done a few now that way - no shocks to date.  :y
Biggest problem with Omegas is lack of space to get at the 3 torx screws holding the bulb holder in.  Drivers side remove air filter assembly - passenger side undo battery clamp and slide battery as far back as it will go.
Some members recommend removing headlights to change HIDs - personally never found the need to do this.
HTH
« Last Edit: 07 September 2011, 22:03:37 by dbug »
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: HID Replacement
« Reply #4 on: 08 September 2011, 10:30:09 »
I have just done both mine and found the easiest way is to fully remove the headlight units to make them easier to get to coe the 3.0 gives you no space at all at thye back of them. Less chance of busting any adjusters too. Bumper removal took 5 mins!
The HID bulb securing ring can be a bit of a sod to ease off so be careful cos they are fairly fragile.
I changed all of the bulbs at the same time cos I do not intend to have to take off the bumper again for a while if I can help it. ;)
« Last Edit: 08 September 2011, 10:31:28 by its.ray »
