Author Topic: Dials cut out and Check Auto Gearbox Problem  (Read 3177 times)
Re: Dials cut out and Check Auto Gearbox Problem
« Reply #15 on: 10 August 2011, 21:12:45 »
Just had Lazydocker give my car the once over :y and it's looking like an overcharging problem, plus I now have a list of things to do for my car  :o
Thanks again Lazydocker :y
No worries :y
sussex peter
  • crawley, w sussex
« Reply #16 on: 27 August 2011, 16:11:24 »
Hiya, my car seems to have a very similiar problem, did you ever get to the bottom of yours? Would be grateful to hear what happened?
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« Reply #17 on: 27 August 2011, 21:07:12 »
Hey,
Well we did notice on my car that the positive terminal crimp was a little bit loose, some of the copper wire was showing so I replaced it with a new connector and it appeared to fix the problem for the most part however when I really drove my car hard the other day, lots of acceleration/deceleration it came back again. It could still be the connector as it is a cheap halfords one, but it certainly improved it by replacing it.
One thing lazydocker noticed was that when my car was running the main positive cable at the battery was a lot hotter than the main negative cable. Which doesn't happen now with the new connector.
Hope this helps a bit :y
« Last Edit: 27 August 2011, 21:07:51 by Satingoth »
Things to do: Air Con still leaking
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« Reply #18 on: 08 September 2011, 22:32:06 »
Everything is back to square one again with error 49 rearing its ugly head.
This time I think it is the electronics on the alternator as it's reading 15.5v idle and 17v when revved a little bit  :'(
I'm going to remove the alternator and have a look, possibly attaching it to a drill to test it.
I shall report my findings but I'm guessing that it was a faulty alternator off epray. I guess I shouldn't be too suprised.
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« Reply #19 on: 10 September 2011, 00:05:48 »
After having removed the alternator it can be seen that although the plastic said bosch the regulator said cheap copy, so definitely an overcharging problem.
I went up to see Twiglet to get another alternator, he also had the wiring loom for the alternator, starter through to the battery so I thought I would change that and get rid of my halfords terminal all for a great price.
So I spent the evening fitting the new loom, alternator, a clean header tank, all from Twiglet :y and now my car has made it's first journey without a hiccup.
Now my next project is to replace all the delightfully blue spray painted bits under my bonnet :o Why would someone paint the engine, especially with rubbish paint that cracks and peels with heat :-? But that's for another thread.
Thanks LazyDocker, Twiglet and everyone else who's helped with this problem :y
twiglet
  • Norwich, Norfolk
« Reply #20 on: 10 September 2011, 00:08:53 »
Page created in 0.031 seconds with 16 queries.
