Pages: 1 2 [3]  All   Go Down
Author Topic: how do you know when to replace a wishbone?  (Read 5116 times)
Re: how do you know when to replace a wishbone?
« Reply #30 on: 12 September 2011, 10:20:39 »
Here is the guide. Although this wb has been removed. Easy to do under the car, and much quicker with the appropriate tools.
http://www.omegaowners.com/forum/YaBB.pl?num=1301673484
I do wonder why we bother with a guide section and recommended methods on OOF when even prominent members can't be bothered to read them!
Polly bushes come in two halfs that just push in. Simples!
« Last Edit: 12 September 2011, 10:21:51 by chrisgixer »
« Reply #31 on: 12 September 2011, 10:51:27 »
As Allan says the rear bush is also shot(sorry,should have re read before my last posts now I have wifi connection) then yes the wb has to come off, obviously.
It is far easier to press a front oe bush in, than press an old one out ime. And easier still to cut the old one out. Weather on the car or off it. Cutting the outer metal ring of  the old bush is the critical part, and obviously stopping short of cutting the wishbone is key. Cut as deap as you dare then chisel and hammer to force the bush outer in on itself while tearing the remainder of the hack saw cut.
There is a perfectly clear guide posted by razzo if you care to look...?  :-?
AA had his pollys fitted in a field at Newent in about an hour. It's not difficult or dangerous in any way...(wtf?  :-? ) although cutting by hand with a hack saw is extremely tedious, granted.
Your clearly volunteering to fit some poly bushes to a certain 3.2 thats in my garage aren't you?  :D  ;D ;D
« Reply #32 on: 12 September 2011, 11:48:20 »
Hang on, he's got to come and do mine practice on mine, first.. ;D
Not that he knows that yet..
« Reply #33 on: 12 September 2011, 12:08:23 »
Chris, you can do as you wish, but I dont think a garage who works like that can take a quality certificate ;D
Why not? So they can charge 4 times as long ?  >:(
It is the recommended way, ask master. And when you "press out" a front bush please post a video. I will be most interested in your first attempt  ;D
years ago when I first replaced the front bushes only (it was boge) it didnt go longer than few months.. changed another time..  second set lasted a bit longer..  all changes done on a big hydraulic press, so it was easy..  however as they didnt last well , I bite the bullet pay the money and buy original GM which last more than 50K (kms).. after that , I give up to pay this money and buy wishbones thats produced in my country which was 1/3 of that price (original GM 380 £ approx) .. its been a year and no problems so far..but I'll try those poly bushes also.. :y
ps: I dont think those wishbones will be safe if bushes changed even with a hyd .press more than a couple of times..  :-/
« Last Edit: 12 September 2011, 12:14:52 by cem_devecioglu »
« Reply #34 on: 12 September 2011, 12:21:59 »
Sounds like the pattern bushes you got cem just did not last long?  :-/
Bit like pattern cam cover gaskets?  :-/
« Reply #35 on: 12 September 2011, 12:22:28 »
 ;D ;D ;D
« Reply #36 on: 12 September 2011, 12:31:11 »
even if it lasts for a year or more.. no probs.. I can buy another.. anyway hourly labor is cheap here and I wont pay any labor also ;D
because I repair their pcs for free >:(
« Reply #37 on: 12 September 2011, 13:05:45 »
Where the wheels hanging when bolts tightened? Ie car in the air?
Pages: 1 2 [3]  All   Go Up
