Author Topic: Noise from the suspension/exhaust  (Read 1364 times)
Robbo_cdx
  • East Mids nr Snottingham
« on: 15 September 2011, 23:35:17 »
Hello again,
I'm going to get the car in the air this weekend as there is a rattling/knocking coming from both front and back.
I'm hoping it's just a loose exhaust, however is there anything I should be looking for/checking with the suspension specifically. I've seen the threads that mention the wishbones at the front, does the rear have any particular areas that need checking
Thanks
Robbo.  :)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Noise from the suspension/exhaust
« Reply #1 on: 15 September 2011, 23:59:15 »
Hello again,
Thanks
Robbo.  :)
wishbones, droplinks. will lead to tyre wear. :y
« Last Edit: 16 September 2011, 00:00:29 by billthebrickie »
Ewan
  • Near Dundee
« Reply #2 on: 16 September 2011, 23:20:55 »
Anti-roll bar drop links wear out quite regularly and make a knocking even when going along a fairly smooth road. The play can be be quite tricky to spot though.
symes
  • oxford
    • R reg 940 volvo
« Reply #3 on: 16 September 2011, 23:29:26 »
at the front check wishbone where it mounts to chassis-usually bush's wear at rear mounting point-my saloon had that and my estate got same-dont matter though as doing them in the morning. also check center exhaust hangers-they split.
« Reply #4 on: 17 September 2011, 11:26:40 »
Hello again,
Thanks
Robbo.  :)
Drop links will not lead to tyre wear. Wishbones however.... Will. Not likely to knock uness the rearward bush has badly failed.
Also check track rod ends.
