Author Topic: Air Con valves  (Read 2635 times)
Re: Air Con valves
« Reply #15 on: 20 September 2011, 18:27:35 »
Re: Air Con valves
« Reply #16 on: 20 September 2011, 18:37:56 »
Found it!!!
http://www.omegaowners.com/forum/YaBB.pl?num=1309525980/all
Ordered :y
 :y :y :y :y Make sure you support the boss that it screws into so  you don't snap the whole lot off the ally pipe.  :y  :y
Valve is 15mm across the flats.   ;)
Re: Air Con valves
« Reply #17 on: 20 September 2011, 18:41:01 »
Found it!!!
Ordered :y
Need to clean mine up so I can actually see what is part of pipe, and what is part of valve, then I should be able to get my head around it :y
Was it tight?
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Air Con valves
« Reply #18 on: 20 September 2011, 18:46:39 »
Got one here TB off the 2.6 elite i will bring it on Saturday. Saying that i must have the pressure checked on the estate as aircon has stoped working in the past few weeks, was OK when i went to Scotland in July. :-?
Re: Air Con valves
« Reply #19 on: 20 September 2011, 18:47:37 »
Found it!!!
Ordered :y
Was it tight?
Mine wasn't particularly tight, they don't need to be .............. but neither does an oil filter cap and we all know how tight they can be.  :-X
Just use your socket over the top, IIRC the bit that it screws to is 17mm across, the valve is 15mm so it won't go any further.  ;) ;)
Re: Air Con valves
« Reply #20 on: 20 September 2011, 18:59:54 »
No need, 2 on order from dealer :y
Re: Air Con valves
« Reply #21 on: 20 September 2011, 19:00:43 »
Found it!!!
Ordered :y
Was it tight?
Sounds like even an idiot can do it ;D
Did it come with the O-ring seal that I can see in your pic?
Re: Air Con valves
« Reply #22 on: 20 September 2011, 19:03:57 »
Found it!!!
Ordered :y
Was it tight?
I asked if they came complete with a seal, he didn't know so I ordered a separate seal .......... so obviously it came with one!  :y :y
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Air Con valves
« Reply #23 on: 20 September 2011, 19:12:59 »
Is there anyone on here anymore that can do a re-gas as i would not like to get ripped off to much. i know simon used to do it but don't think he is around on here anymore. :-/ :-/
Re: Air Con valves
« Reply #24 on: 20 September 2011, 19:18:21 »
Halls Electrical in the Blagrove Industrial Estate do a good job for just under £40
http://www.hallsautoelectrical.co.uk/air-conditioning
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Air Con valves
« Reply #25 on: 20 September 2011, 20:54:21 »
Used them before Nige cost me £300 and each time they found another cash builder :-[ :-/
