Author Topic: Tuning Mods for 3.2  (Read 1622 times)
rajveer.sandhu
Tuning Mods for 3.2
« on: 20 September 2011, 09:58:20 »
Can 4x G-Cams be put into a 3.2v6 the same way a 3.0v6 can have 4x G-Cams?
In real terms, which would have faster acceleration -
a 3.0v6 with 4x G Cams and 3.2 Manifolds
or a 3.2v6 with 4x G Cams (and already have 3.2 Manifolds).
Re: Tuning Mods for 3.2
« Reply #1 on: 20 September 2011, 10:37:50 »
if a manual 3.2 not enough for you, buy something faster..
« Reply #2 on: 20 September 2011, 10:40:35 »
 ;D ;D
Yup, not a lot you can do to the 3.2 to make it faster, any changes may give slight improvement, but if you want a lot more go, stick a V8 in  :y
2woody
  • Northumberland
« Reply #3 on: 20 September 2011, 10:43:55 »
a shorter diff would eclipse each of those options.
you have very little ability for the fuel injection to compensate for the different cams, so unless you're prepared to add an after-market ECU then the gains would be very small.
« Reply #4 on: 20 September 2011, 10:46:59 »
Got a 4.22 diff here.Iirc thats shorter than standard 3.0/3.2 ? :-/ ;) ::)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #5 on: 20 September 2011, 17:16:33 »
;D ;D
Thats the ONLY way in my eyes  ;) ;D ;D ;D
« Last Edit: 20 September 2011, 17:17:40 by Stallion »
« Reply #6 on: 20 September 2011, 18:51:51 »
Sigh....
A 4.2 dif. With a manual box, as it's gears are shorter.
« Last Edit: 20 September 2011, 18:52:22 by chrisgixer »
martin42
« Reply #7 on: 20 September 2011, 18:56:18 »
You could fit a won nitrous wet kit with progresive controller
« Last Edit: 20 September 2011, 18:58:01 by martin42 »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #8 on: 20 September 2011, 19:21:44 »
If my 3.2 was any quicker ( and it's an auto estate) i would not have my licence for much longer. :-? :-?
« Reply #9 on: 20 September 2011, 19:28:35 »
I reckon a standard well maintained 3.0l is quicker than a std well maintained 3.2l, everything else equal.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #10 on: 20 September 2011, 19:31:54 »
The way you drive i think my estate in your hands would turn my hair white (live life to the full) :o ;D ;D
« Reply #11 on: 20 September 2011, 19:34:11 »
Ex-plod? Manual with LSD?  If so, they leave the line quickly, if you get the traction right :y
« Reply #12 on: 20 September 2011, 19:38:17 »
I would call NASA and turn it to a rocket spaceship so nothing can beat ;D ;D :P
sorry..
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #13 on: 20 September 2011, 19:49:57 »
It is ex-plod but auto elite as they got it from the show room. I had the manual last time and boy that was quick. :o :o :o
« Reply #14 on: 20 September 2011, 22:09:09 »
ok.. being serious, modding a 3.2 for some good gains requires serious effort.. simple mods combined you will get around 20-30 hp at maximum which wont decrease timing of 0-60 enough (considering the weight and stock hp) .. so, for a higher performance increase you will need deep pockets whatever mod you apply..
so as a conclusion wont be economical..it will be much practical to buy a turbo car which can be mapped and already built for those powers..
the reason why I said buy another car.. :y
also I want to add, another car not necessarily mean import jap turbos.. even a calibra turbo have much better power/weight ratio.. parts would be cheaper than jap cars and can be easily mapped to 300 hp.. although I have seen higher hp examples..
« Last Edit: 20 September 2011, 22:16:22 by cem_devecioglu »
Page created in 0.023 seconds with 20 queries.
