Pages: 1 2 [3]  All   Go Down
Author Topic: Steaming up, but only when it is raining!  (Read 5484 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Steaming up, but only when it is raining!
« Reply #30 on: 20 September 2011, 00:35:41 »
My estate has always steamed up easy as well if "eco"is pressed,car is dry as a bone inside but has always done it,mind you our Ulysses is the same hence runs with aircon on most of the time
other rides
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #31 on: 20 September 2011, 12:14:06 »
This has been covered a couple of times before but a couple of years ago so can't find the posts. Mark DTM posted an explanation to do with a voltage drop causing the control flaps not to recognize the correct starting positions. IIRC it required to air recirculation button to be pressed for a few seconds but maybe Mark will confirm. I've had this problem with Omega's over the years and this has always worked.
« Reply #32 on: 20 September 2011, 12:16:41 »
Switch on Auto mode, switch-on the air recirculation by pressing the button A once (3 round arrows will be indicated, without "A" in the middle). Now the ECC will recognize the correct flap position. Wait 1-2 s and then switch-off the air recirculation by pressing the button A again.
bob.dent
  • Hertfordshire
« Reply #33 on: 20 September 2011, 12:34:53 »
Thanks Rob, that was it. :y
philsteward
  • Leeds, West Yorkshire
    • 2001 2.2CDX Estate LPG
« Reply #34 on: 20 September 2011, 21:26:11 »
Thanks for all the replies and advice.  Not had a chance to look at the car today, hopefully tomorrow!
I have cleaned all the windows in the car, first thing I did when it started steaming up as as people have said it makes it even worse!
I have tried the "resetting" the recirc button, but makes no difference.  Mark Calib said that the recent update to the Climate Control system should help as well, it has a bit but still steams up.
Will check my scuttle again, check the condition/wetness of the 2 month old pollen filter, check under the carpets, check operation of the recirc flaps and see if I can find the external vents in the rear...phew that is a long list..but if it cures it! ;D
Cheers again, shall update when I know more :y
  • Auckland
    • Mazda MPV
« Reply #35 on: 20 September 2011, 21:56:26 »
If you try switching the recirc on and off with the fan on full speed there should be a noticeable difference in the sound (IIRC the recirc flap pulls air from the passenger footwell and huffs and puffs quite audibly ::))
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #36 on: 20 September 2011, 22:25:46 »
My car does exactly the same as yours Phil, the aircon will clear it instantly but on eco it'll steam up so that you can't see out within 30 seconds! My scuttle drains are clear and there's no damp carpets, I think it must be an Omega thing  :-/
Never experienced this in any other car quite as badly  :-/
« Last Edit: 20 September 2011, 22:26:47 by jmdavies »
philsteward
« Reply #37 on: 21 September 2011, 08:27:00 »
This is what I was begining to suspect. But it cannot surely have happened from when the cars were brand new? Anybody on here had an Omega from brand new with this issue? I reckon not, therefore it must be possible to stop it!
Martin_1962
« Reply #38 on: 22 September 2011, 09:45:17 »
I never turn off aircon - bad for the pump.
jonnycool
« Reply #39 on: 22 September 2011, 12:50:33 »
I do, it's bad for my wallet  :)
« Reply #40 on: 22 September 2011, 12:56:41 »
Also bad for the A/C seals as they dry out which in turn will lead to leaks in the system
philsteward
« Reply #41 on: 22 September 2011, 13:01:12 »
Think this is a bit extreme.  The pump has a clutch which is designed so the engine can run without the air con pump working, hence it will be fine.
I think the point you are making is that as RobG has said the seals can dry out if air con is not used, however this would take a period of time, over a couple of weeks in extreme conditions, using air con once every two weeks should be more than sufficient.
In fact your air con system can loose upto 15% of its gas each year, so if you are running the pump but not had your system regassed in the last two years, you could well be doing more harm!  :o
jonnycool
« Reply #42 on: 22 September 2011, 13:03:15 »
Does this apply in the winter, when you don't use it to cool?
philsteward
« Reply #43 on: 22 September 2011, 13:22:50 »
Yep, slightly more so in fact as the cold weather cools the seals, and then the heat from the engine warms them, so they are getting constant changes in temperature but no lubrication.
You only need to use the air con for long enough for it to blow cold, that is enough to circulate the oil.  I normally use mine once a week for about 15mins.
During the summer I use it when on the motorway (as it is cheaper than having a window open), and in the winter I use it to clear the steam from the inside of the window.
By the sounds of it, it is a necessity to use it through the winter in an Omega! ;D
Pages: 1 2 [3]  All   Go Up
