Author Topic: Oil Sump Nut!  (Read 4435 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Oil Sump Nut!
« Reply #15 on: 22 September 2011, 00:52:37 »
is it really worth buying asecond hand sump when they're not that expensive new?  :-?  :-?
Possibly shed some light how much they might be new or maybe provide the p/n an i can have a look!  :y :y
« Last Edit: 22 September 2011, 00:53:12 by Stallion »
Re: Oil Sump Nut!
« Reply #16 on: 22 September 2011, 06:41:25 »
The lower sump pan on a V6 is steel, however the drain plug screws into an ally boss pressed into the steel pan. I forget now how much a new pan is - £30 or £40 IIRC but rather than messing about with a Helicoil  ......
 ::) ::) ::) local dealer's parts desk will have a part number  :y
« Last Edit: 22 September 2011, 06:48:59 by Andy_B »
Stallion
  • Romford
Re: Oil Sump Nut!
« Reply #17 on: 22 September 2011, 14:38:54 »
FAR FAR AWAY dealer's parts desk did have the part no. As its a common problem and to help anyone in future finding it. ;)
Sump pan with the nut p/n 9158421  :y :y
« Last Edit: 22 September 2011, 14:40:22 by Stallion »
Re: Oil Sump Nut!
« Reply #18 on: 22 September 2011, 15:49:09 »
and they cost ............. ?  ::) ::)
Stallion
  • Romford
Re: Oil Sump Nut!
« Reply #19 on: 22 September 2011, 16:48:22 »
£61.20 :y
Re: Oil Sump Nut!
« Reply #20 on: 22 September 2011, 19:17:52 »
£61.20 :y
they've gone up a bit in the past 4 or 5 years then .....  :-?
Re: Oil Sump Nut!
« Reply #21 on: 22 September 2011, 23:39:35 »
I had mine helicoiled for £60! That was 4 years ago tho, but it's been fine since  :y
Is it worth removing the sump, with all the mess and hassle (Yes I've done it!) if you can get it helicoiled for about the same?  ::)
I know what I'd do..... ;)
Agemo
  • Cleethorpes
  • Insignia
Re: Oil Sump Nut!
« Reply #22 on: 23 September 2011, 19:24:40 »
I Helicoiled mine today, took an hour & a half including draining the oil. It was a doddle to do in situ, and the kit cost me less than a tenner (from "dlg-07999535899" on ebay).   :y
