Author Topic: NCD2013 wiring for car kit  (Read 27779 times)
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« on: 22 July 2006, 18:36:13 »
I'm finally getting round to transferring the nokia car kit between cars and am now at the point of making power and mute connections. I've identified the power connections (tapping into the trafficmaster adaptor lead), anyone know which wire to connect to implement the radio mute function?
Re: NCD2013 wiring for car kit
« Reply #1 on: 22 July 2006, 18:37:18 »
iirc, the pinout is on a sticker on the radio...
sounds2k
« Reply #2 on: 22 July 2006, 18:53:38 »
(pops out to car to grab radio) ... yep so it is!
top of radio is a sticker with model no., etc - and the pinouts (helpfully upside down!)
so here's a close-up of it the right way up!
looks like pin 34 - pink with two red stripes - which also goes to trafficmaster wiring connector which makes sense!
« Reply #3 on: 22 July 2006, 19:00:19 »
Glad thats sorted :) - I hope you have your radio code for when you put it back in  :P
sounds2k
« Reply #4 on: 22 July 2006, 22:48:01 »
works perfectly (as hoped) - mutes stereo, shows "external audio source" on GID, then resumes CD (or internal changer) where it left off ... perfect !
Oddly enough, although I do have the code, I never got asked for it! Not sure, maybe as the display and head units are coded to each other, I guess it recognises that it's connected to the same display unit so assumes that all is well. I did try holding down AS while powering on (which toggles the code on a lot of Vx factory head units) and it did nothing ... ??
« Reply #5 on: 23 July 2006, 09:12:45 »
Possibly - I know thradio and screen are coded together with this setup.
Not something I've played with - I'm stuck in prefacelift world...
« Reply #6 on: 23 July 2006, 13:36:38 »
They dont have a code.....got the schematics for this setup here......
