Author Topic: Adding headlamp washers  (Read 6080 times)
Martin_1962
« on: 05 September 2006, 09:21:04 »
I will be converting to HID in the next couple of months, however I do want headlamp washers, how much work too fit?
Re: Adding headlamp washers
« Reply #1 on: 05 September 2006, 09:58:24 »
New washer bottle, pump, pipework and washer jets. Not sure on facelift if there is much else, as I suspect the loom is there. You will need to drill the bumper.
Prefacelift would need the washer extenders as well, and the trim under headlight drilled...
« Reply #2 on: 05 September 2006, 09:59:30 »
Remeber if you are doing HIDs properly, you need the level sensors, not sure if its a seperate ECU, and you MID reprogrammed to tell it about the HIDs.
« Reply #3 on: 05 September 2006, 10:03:16 »
It is a seperate ECU...
Martin_1962
« Reply #4 on: 06 September 2006, 11:55:01 »
Looks like time to scour the breakers, might fit self leveling suspension or HD springs.
Tunnie does this a lot doesn't he?
Not many breakers near me and they are not DIY strip
« Reply #5 on: 06 September 2006, 15:25:47 »
no hid omegas in tunnies local scrappy...
Martin_1962
« Reply #6 on: 06 September 2006, 21:29:22 »
Never mind - I'll start a wanted thread
« Reply #7 on: 07 September 2006, 11:13:50 »
Yup, sorry no HID's  :(
I would't mind a HID conversion for my facelift, looks like a LOT of work though.
« Reply #8 on: 07 September 2006, 12:03:22 »
Buy a new car instead. How about a nice 1998 silver MV6 ;)
BILL0BLU
  • Isle of Anglesey
« Reply #9 on: 04 October 2006, 14:56:44 »
Before fitting HID's check out the price of replacement bulbs. I was going to go down the HID road because the head lights on my 95 2.5 were crap but because of the price of new bulbs I manageg to pick up nearly new headlight unit and used 30% brighter H1 bulbs, not the blue ones and now I'm more than happy with my night driving.
I think you'd be disapointed with the blue bulbs, I was.
Martin_1962
« Reply #10 on: 04 October 2006, 21:12:01 »
Used to be easy 80/100 headlamp and 130w driving lights on the Sunbeam.
Anyway I think I will HID convert as they are good
Martin_1962
« Reply #11 on: 04 October 2006, 21:13:22 »
Bit old and I still owe quite a bit on the 2.6, not to mention all the work required to gas it
Page created in 0.141 seconds with 20 queries.
