Author Topic: blaupunkt cdc2 changer  (Read 4429 times)
bear33
  • Essex
« on: 15 November 2006, 10:19:38 »
Ive brought a second hand one from e-bay and i need to change the angle from 0 to 90 degrees.Could anyone tell me how to  please.Also can i get the code if needed from vauxhall bearing in mind i dont know what car it came from?
Thanks
Chris
bear33
  • Essex
Re: blaupunkt cdc2 changer
« Reply #1 on: 15 November 2006, 10:34:41 »
DAMN.Just tried cd player and it coming up with cd error  >:(
Did same on the one ive already got.
Im wondering if it could be the headunit at fault now
« Reply #2 on: 15 November 2006, 11:32:19 »
or cable?
bear33
  • Essex
« Reply #3 on: 15 November 2006, 11:34:59 »
Is the cable part of the loom or is it a seperate cable?
Also has it got a plug at head unit end or is in included in iso connector?
I only have one plug on the back of my head unit (crc 800) which im assuming is the aerial coonection
« Reply #4 on: 15 November 2006, 11:40:25 »
Not part of loom.
CDC cable will go into ISO connector, though from memory, once unclipped from cage is a seperate plug...
bear33
  • Essex
« Reply #5 on: 15 November 2006, 11:43:25 »
Im assuming its all connected properly as sometimes my old cd player use to play.
The second hand one i just bought wont play at all.It loads the cds 1-6 but comes up cd-er
JUST ANOTHER OF THE FEW ANNOYING FAULTS I HAVE WITH MY CAR  :(
« Last Edit: 15 November 2006, 11:45:59 by bear33 »
bear33
  • Essex
« Reply #6 on: 15 November 2006, 14:35:58 »
Dont suppose you can buy an after market cd/tuner that will allow me to use the bose system still?
