Author Topic: Replacement Radio For Omega CDX  (Read 11985 times)
philayl
  • Wirral, Merseyide
« on: 03 December 2006, 18:41:11 »
Hi All, can anyone suggest a suitable replacement for the radio I have fitted at present, I have the Phillips CRT 700?, I think that is the model, it has the intergrated telephone. I would like a cd changer setup, as at present, or one that will play DVD music discs. It must be capable of being connected to the steering wheel remotes and preferably still show on the MID display, I realise to acheive this I will need adaptors. Can anyone recommend a make and model of radio, tell me what adaptors I will need, and how much approximately it will cost me?  Many thanks,  p.s the car is a 1999 2.5 CDX Omega (Mini Facelift)
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: Replacement Radio For Omega CDX
« Reply #1 on: 03 December 2006, 19:03:57 »
Is your display like this?
if so, you should be able to interface the head unit with the steering wheel controls, but good luck getting it to talk to the display! My old car had a kenwood head unit fitted, the display didn't work - I bought a different wiring adaptor and that didn't operate the display either  :'(
Both adapted the steering wheel controls though  :y
It should be fairly easy to implement though, as you won't have the bose setup with its' amplifier sat between the head unit and speakers to complicate matters  :)
« Reply #2 on: 03 December 2006, 22:06:06 »
You ain't got a cd changer in the boot then - check behind first aid panel right side of boot. All factory fitted CCRT700 came with the changer...
philayl
  • Wirral, Merseyide
« Reply #3 on: 04 December 2006, 14:09:11 »
Hi sounds2k, yes my display is the same, I also have the telephone display in the bottom right section.
Hi The Boy, yes it has a Blaupunkt 6CD changer in the boot, but it is skipping all the time, even on bought CD's. I would be happy with a a unit that played DVD audio discs, and do away with the CD changer, or if it is more economic, stay with the CD changer arrangement, maybe a 10 or 12 disc changer with MP3 capability. The only must have is steering remote capability, and a "would like" is to keep the in dash display. Back to work now, will check back after six this evening.
philayl
  • Wirral, Merseyide
« Reply #4 on: 06 December 2006, 12:17:25 »
Bump
Admin
« Reply #5 on: 06 December 2006, 13:29:51 »
If going aftermarket, what is your budget?
The Administrator.
Phil
« Reply #6 on: 07 December 2006, 11:45:42 »
Nobody makes and adaptor that works with the GID, so if you change the HU you loose the info on the display
« Last Edit: 07 December 2006, 11:46:53 by Phil »
philayl
  • Wirral, Merseyide
« Reply #7 on: 07 December 2006, 19:10:34 »
Hi Laidback, my max spend will be about £250.
Hi Phil, I was hoping that keeping the display was possible, oh well never mind.
Phil
« Reply #8 on: 07 December 2006, 21:33:33 »
You have PM
Admin
« Reply #9 on: 08 December 2006, 13:43:29 »
£250?
For me, it is the Pioneer DEH-P8600MP. Nothing better for the money (£160ish s/h from ebay).
The Administrator.
philayl
  • Wirral, Merseyide
« Reply #10 on: 08 December 2006, 18:56:54 »
£250?
Hi Dave, can this be wired to steering wheel controls?
Admin
« Reply #11 on: 08 December 2006, 20:30:51 »
This answers your question :)
http://caraudiosecurity.com/shop/product/products_id/2243.html
Oh, and here is a good review of this stunning headunit.
http://www0.epinions.com/content_186902679172
The Administrator.
philayl
  • Wirral, Merseyide
« Reply #12 on: 09 December 2006, 11:01:36 »
Thanks for the info Dave, am looking seriously at it.
bexandpower
  • norwich
« Reply #13 on: 13 December 2006, 18:15:00 »
Try http://www.caraudiodirect.co.uk they were pretty cheap when i wanted to get some bits plus they do most adaption leads and speaker housings. Plus this one for under £200 is a rather tasty unit http://www.caraudiodirect.co.uk/alpine-cda9812rb-p-2193.html
« Reply #14 on: 13 December 2006, 18:36:51 »
just thought i would show my headunit (Alpine 9854R) sounds fantasic and really improves the sound. The bass from the standard speakers is much better compared to the weak vauxhall unit:
