Author Topic: alarm faulty  (Read 4627 times)
andi
  • warrington (NW)
alarm faulty
« on: 22 January 2007, 19:23:40 »
my alarm light flashs when i arm the thing. it say in the book tht it should stay on then it'll start flashing. my cenral locking works but i dont think the alarm is setting as ive not managed to set it off either! it says thealarm is self diagnosing so how do i find out whats wrong with it? cheers guys!
mines the i/r type on a 1994 elite estate
nixoro
  • Hitchin, Herts
Re: alarm faulty
« Reply #1 on: 23 January 2007, 09:50:48 »
I had a similar problem on my dads omega, I found the alarm horn under the scuttle the contacts were corroded and so it wasn't doing anything.
When sat in the car do the sensors pick up any movement when you lock and the light settles and starts to flash, only even though my dads alarm horn wasn't working I confirmed the sensors were due to a relay which started to click behind the glove box.
I believe there has been a scuttle removal guide started by Theolodian, The horn itself should be located on the drivers side under the scuttle.
HTH
« Last Edit: 23 January 2007, 09:51:45 by nixoro »
nixoro
  • Hitchin, Herts
Re: alarm faulty
« Reply #2 on: 23 January 2007, 09:56:00 »
Here is the link
http://www.omegaowners.com/forum/YaBB.pl?num=1164147199
Worth a look as it could be something simple. :y
