Author Topic: eratic temp gauge. not overheating tho  (Read 4573 times)
andi
  • warrington (NW)
« on: 21 January 2007, 09:34:33 »
my temp gauge seems to move when im traveling at 80 mph (on a private rd) up to the 100 and sometimes past it. if i turn the heater blower on to full it very offen increases the temp readout by 5-10 deg's. if i slow down again or turn the heater of it will drop. when slowing down it will drop rather quickly and just seems like an electrical fault as i dont think that the car would cool down that quick.
any ideas guys? thanks
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
Re: eratic temp gauge. not overheating tho
« Reply #1 on: 21 January 2007, 09:54:00 »
It could be a dodgy sender, dodgy gauge, dodgy connection, alternator over/under volts.
« Last Edit: 21 January 2007, 09:54:36 by Hillper »
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
« Reply #2 on: 21 January 2007, 11:16:59 »
worth flushing coolant as matter of course anyway.
also measure battery voltage with ign off, and also at 2500rpm...
« Reply #3 on: 21 January 2007, 11:33:38 »
sounds like crap in the coolant to me, after a coolant flush in my 2.2 it was very eratic for a few miles but then settled down.
andi - when was the coolant last FLUSHED and not just topped up, also is it blue or Red?
andi
  • warrington (NW)
« Reply #4 on: 03 February 2007, 10:27:42 »
tuned out to be the waterpump. it was getting worse so i changed the thermostat and tried again but a vx mechanic tol me to look at the pump. half of its plastic impellor had broken away. in he space of 3 days ive fitted a water pump to my mates 2.0 omega and now my td! are they all that bad?
Admin
« Reply #5 on: 03 February 2007, 20:33:45 »
No, they are not that bad.
But like all mechanical parts, they have a finite life.
Water pumps are one of those things that frequently get overlooked on servicing.
I choose to change mine with the cambelt (V6 petrol).
On a 2.0 4cylinder it is imperative to change with cambelt every 40k as it is driven by the cambelt (V6 is driven off the aux belt).
On a diesel it should be good for 50-60k easily. I suspect yours may have been considerably older...
Lucky escape though. That could have been a LOT worse.
The Administrator.
« Reply #6 on: 05 February 2007, 05:33:58 »
Agreed.
Thinking back, I reckon the pump was the cause of the evils on my 3.0 Elite M reg that I got rid of.
Page created in 0.009 seconds with 20 queries.
