Author Topic: ccr 2006 radio  (Read 4614 times)
bonnie boy
  • near King's lynn
ccr 2006 radio
« on: 03 February 2007, 13:56:53 »
hi there my omega has got a cdr 2005 radio and i would like to put a ccr 2006 in it can anyone tell me if i will need a new cage for it as it has two units instead of the single unit on the cdr 2005 many thanks
Admin
Re: ccr 2006 radio
« Reply #1 on: 03 February 2007, 20:28:20 »
CCR 2006 is exactly the same double DIN fit as the CDR 2005.
Just be careful when buying a CCR 2006.  The 4 disc changer had some problems and would refuse to read discs.
Repair is neither easy or cheap (unless you happen to be an electronic whizz!)
They are also  :-Xing expensive!
Have you contemplated an aftermarket single DIN unit with MP3 capability?
Easy to fit and simply get a blanking plate for the space.
Oh and unless you happen to be an audiophile the sound quality is much improved. :)
The Administrator.
Re: ccr 2006 radio
« Reply #2 on: 05 February 2007, 09:50:40 »
Yes you will, mainly thanks to the 2005 being a single din with a double din front panel....
Admin
Re: ccr 2006 radio
« Reply #3 on: 05 February 2007, 10:52:01 »
I stand corrected!  :-[ I was completely unaware that the 2005 was single DIN behind front (although it does make sense)
If you end up needing a cage I have one. :)
The Administrator.
bonnie boy
  • near King's lynn
Re: ccr 2006 radio
« Reply #4 on: 12 February 2007, 05:22:26 »
Thanks guys got a cage now just waiting for CD CARTRIDGE TO COME OFF OF EBAY BRAND NEW
SteveD
  • Blackpool (no casino)
Re: ccr 2006 radio
« Reply #5 on: 19 February 2007, 21:52:59 »
..and watch for the thing going nuts when your battery goes flat. Mine has tuner & cass working fine but CD is SAFE. Looks like a few others are having this problem too  :'(
paulr
  • Frodsham
Re: ccr 2006 radio
« Reply #6 on: 24 February 2007, 16:15:45 »
yup I have that problem as well
