Pages: 1 [2] 3  All   Go Down
Author Topic: Bose system  (Read 26042 times)
Bo Bo
  • Coventry
Re: Bose system
« Reply #15 on: 03 April 2007, 11:02:34 »
OK, I've sussed the bass/treble.
I'd changed the setting to 0 on the radio, the CD is still on +3, still can't get it to switch off without taking the security panel off though...
Not that familiar with the ccrt unit, unlike the earlier car300/400/ccr600/800 units which all operate the same way.  It may be one you may have to look up in manual. Do you have one?  If so, look for On/Off Logic....
Yes, I took a quick look at it, I'll have a good look through it today....
Bo Bo
  • Coventry
Re: Bose system
« Reply #16 on: 03 April 2007, 14:03:29 »
OK, think I have a problem with my head unit  :-/
Read the manual & it says it's operated with the key with ignition logic on & with the on/off button with it off. I've tried both setting & it will switch on but won't switch off without removing the security panel.
It looks like it's been taken out at some point too because a couple of the grub screws have not been put back in all the way........
Re: Bose system
« Reply #17 on: 03 April 2007, 14:10:12 »
You are removing key from ign?  It will stay on if you don't.
Sincere apologies if I'm teaching you to suck eggs  :-[
Bo Bo
  • Coventry
Re: Bose system
« Reply #18 on: 03 April 2007, 14:50:41 »
No worries, doesn't matter if key's in ign or not it won't switch off with on/off button.
I locked the car & left it for an hour & 1/4 but it was still on when I went back....
Re: Bose system
« Reply #19 on: 03 April 2007, 14:58:36 »
I wonder if you have an ignition problem, rather than radio issue??
I guess unit swap with someone to see if fault goes with stereo or stays with car.  Assuming you have the codes of course.
Bo Bo
  • Coventry
Re: Bose system
« Reply #20 on: 03 April 2007, 15:01:33 »
Sat Nav works as is should.
Yes I have the codes, doesn't theolodian have one of these?
Re: Bose system
« Reply #21 on: 03 April 2007, 15:02:28 »
Yes he has. Not sure if he has his codes though...
Bo Bo
  • Coventry
Re: Bose system
« Reply #22 on: 03 April 2007, 15:11:52 »
OK I'll PM him  :y
Bo Bo
  • Coventry
Re: Bose system
« Reply #23 on: 03 April 2007, 15:47:04 »
Just thought; he does have the codes because his battery went flat when he was in the US at xmas/new year.
Re: Bose system
« Reply #24 on: 03 April 2007, 17:32:39 »
Ive done mine so the codes are not needed on the stereo or CD.
Bo Bo
  • Coventry
Re: Bose system
« Reply #25 on: 03 April 2007, 18:11:35 »
I read that option in the manual just before I left for work  :y
Bo Bo
  • Coventry
Re: Bose system
« Reply #26 on: 03 April 2007, 18:31:32 »
Hhhmmm, well now I'm not so sure.
I left the radio on while filling up, when I restarted the Sat Nav was saying insert CD.
Checked when I got to work & it had been ejected, will monitor this over the next couple of days....
theolodian
  • I need a new avatar.
Re: Bose system
« Reply #27 on: 03 April 2007, 19:18:21 »
Assuming yours is the same as mine;
The on/off button is on the top left of the main selector knob, says 0/1
The bass and treble are set independently for each function; radio, tape, CD
I have the codes for mine.
I don't think you can eject the Sat Nav CD from the head unit, so maybe issue is with the Sat Nav unit in the boot.
I am going to Cornwall this weekend and don't want to be without sound.
Bo Bo
  • Coventry
Re: Bose system
« Reply #28 on: 03 April 2007, 19:34:56 »
OK no probs, I can live with it for a while, it's just a tad annoying!
I'm going to take the head unit out on Saturday & have a poke around....
Re: Bose system
« Reply #29 on: 03 April 2007, 23:52:52 »
It could be that someone has had a different head unit in there, swapped the power connections over on the ISO connectors and then put the old one back in to sell it without swapping the supply connections back.
Have a look behind the unit and see if there are signs of bodgery.
Pages: 1 [2] 3  All   Go Up
