Author Topic: Steering Wheel Control Wires  (Read 5085 times)
Craig_R
  • Watford
« on: 20 April 2007, 22:42:06 »
Hiya Chaps
I wonder if anyone can help I am making my steering wheel controls control my car audio software on my in car computer by using a usb gamepad
This link will help explain
http://www.stevieg.org/carpc/install/building/#swc
I need to know where the wires end from the steering wheel controls so i can connect them to the usb gamepad.
If someone knows which wires connect to which buttons on the sterring wheel ?
Thanks
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Steering Wheel Control Wires
« Reply #1 on: 23 April 2007, 11:32:24 »
There are only two wires and a set of resistors so pressing each button presents a different resistance to the audio device.....and given that its fed via the column squib.....adding extra wires is not an option
Craig_R
  • Watford
« Reply #2 on: 24 April 2007, 09:28:53 »
Ahhhh Bugger
I wonder if i can make a module of some sorts to get around this ie wire comes from controls enters module which has six wires out.
but i doubt it i am not that clever.
so there is no chance of adding wires because of the column squib ?
Mod's
« Reply #3 on: 24 April 2007, 10:21:10 »
Your best chance of getting that into a PC would be to use an analogue input of some kind. Maybe a joystick port? Depends what the software you're using supports, of course.
It wouldn't be impossible to decode the signal into individual outputs but it would be a bit of work. Could do it with a PIC or AVR microcontroller with an analogue input and a handful of digital outputs.
« Reply #4 on: 24 April 2007, 11:24:34 »
or a few comparators or transistors......you know, real electronics ;)
« Reply #5 on: 24 April 2007, 12:20:30 »
True.  :)
And while it seems easier to write a few lines of code than to electron-herd at that level I suspect if I were to try and get my head round the PIC instruction set again I'd drive myself insane.
« Reply #6 on: 24 April 2007, 12:26:47 »
The basic PIC instruction set can be written on a fag packet!
Craig_R
  • Watford
« Reply #7 on: 24 April 2007, 16:07:04 »
Right Think I have Found what I need to control the PC from the Steering Wheel Controls
http://www.mp3car.com/vbulletin/input-devices/25690-steering-wheel-controls.html
All I need to know now is which Wires are for Steering 1 set of controls and Steering 2 set of controls
I am rubbish at soldering so this should be fun Grrr lol
Craig
Mod's
« Reply #8 on: 24 April 2007, 19:17:24 »
There is only a single wire for all 6 buttons....its on pin 4 at the rear of the steering wheel squib....Blue/Red stripe.....as each switch is pressed it presents a different resistance to this wire......the other side of the switches/resistor combinations are already connected to 0V
