Author Topic: CDC code  (Read 3629 times)
ducati-boy
  • Dartford, Kent
CDC code
« on: 28 May 2007, 16:26:15 »
Hi Guys
can anyone tell me if i order a new carpass will it have the code for the cd changer on it ?
I had to disconnect the battery because of an alarm fault and when reconnected, the radio/tape/phone all work fine but the cdc says it is safe.
thanks
Tony :'(
« Last Edit: 28 May 2007, 16:27:47 by ducati-boy »
philayl
  • Wirral, Merseyide
Re: CDC code
« Reply #1 on: 29 May 2007, 15:38:31 »
Hi Guys
thanks
Tony :'(
Hi Tony, provided the CD changer was factory fit, and it hasn't been changed, the code will be on the car pass. If you have a couple of dealers in the area get prices off them all, as the cost can vary dealer to dealer.
cdx25
  • Plymouth, UK
Re: CDC code
« Reply #2 on: 30 May 2007, 16:03:19 »
Hi Guys
thanks
Tony :'(
Unless you are sure the unit is the one installed originally, then it may be worth pulling the unit for the audio unit serial number and they will check this.  (And can give you the right code for the right unit!)
Jon
ducati-boy
  • Dartford, Kent
Re: CDC code
« Reply #3 on: 30 May 2007, 18:48:18 »
Thanks for the advice guys
Tony :y
