Author Topic: Alpine CDM-9803rm  (Read 3227 times)
VX1
  • Reading, Berkshire
Alpine CDM-9803rm
« on: 29 July 2007, 00:09:53 »
I am putting this head unit in my 95 Omega, the thing is how can you connect it up to come on with the ignition and keep the station's that you program in? It tends to be a bit annoying every time I turn it on I have to reprogram the station time after time its just stupid. Anyone help?
Vx Trade club card holder
Halfords trade card holder
Re: Alpine CDM-9803rm
« Reply #1 on: 29 July 2007, 01:04:00 »
You need to swap the permanent and switched live connections on the ISO connector at the back. If you're using an adaptor cable this is usually the red and yellow wires. Many have bullet connectors so you can swap them. Failing that you can sometimes tease the pins out of the ISO connector using a very small flat bladed screwdriver to push the little latches in, and just swap the two pins over on one of the connectors.
VX1
« Reply #2 on: 29 July 2007, 01:07:22 »
So let me get this right, if I swap the red and yellow wires around on the ISO connector (on the radio) this should keep the memory for the programed stations AND turn on when I turn the ignition on?
« Reply #3 on: 29 July 2007, 01:11:32 »
Yep. Vauxhall's wiring differs from the standard so you need to swap these two over.
VX1
« Reply #4 on: 29 July 2007, 01:23:12 »
Cheer's will do in the morning and let you know if works or need to get intouch with the insurance company for a new car!  ;D ;D ;D
« Reply #5 on: 29 July 2007, 13:44:04 »
Just in case, to double check - ISO connector pinout here: http://www.bluespot.co.uk/stock/iso.asp
You need to swap the +12v battery and +12v ignition pins over.
VX1
« Reply #6 on: 29 July 2007, 16:23:53 »
Cheers Kevin swapped over the wires and..................................
IT WORKED WITH NO BANG.   :y :y :y Thanks for your help kev.
