Author Topic: Steering wheel audio controls  (Read 2783 times)
« on: 06 August 2007, 16:14:02 »
 :-? What`s the procedure for removing the audio control switches from the steering wheel. When I press to increase volume it decreases and when I press to decrease volume nowt happens. I assume that the switch is knacked. Any advice would be appreciated.  :)
Re: Steering wheel audio controls
« Reply #1 on: 08 August 2007, 17:01:34 »
Disconnect battery and remove steering wheel airbag (two screws from the rear) then everything is pretty obvious!
« Reply #2 on: 08 August 2007, 18:40:22 »
 :y Cheers Mark. Not having tinkered with the steering wheel was a bit dubious regarding airbag and airbag light [smiley=tekst-toppie.gif]
edwardmickey
  • Milton Keynes
« Reply #3 on: 09 August 2007, 11:17:55 »
Just in case you're unlucky to be as dopey as I was, the yellow connectors to the airbag squib with 'warning' all over it, they do disconnect by prising the clip up with flatbed screwdriver.
Keith
« Reply #4 on: 09 August 2007, 12:07:42 »
OK thanks for the tip :y
Craig_R
  • Watford
« Reply #5 on: 09 August 2007, 12:23:39 »
Tis best to leave the car disconected from the Battery for about 5 odd mins to let it discharge itself.
Do you know the way to disconnect the battery ? do it within 15 seconds of turning the ign off and removing the key or you will set your alarm off
Mod's
[To be Fitted]Reverse Sensors
