Author Topic: Alarm on Elite....  (Read 3817 times)
PaulyQ
  • Hartlepool
Alarm on Elite....
« on: 10 August 2007, 00:46:58 »
Weird one this.....
Open door on car.. no alarm, put keys in... no alarm.... turn keys to II... Alarm... Start car... No Alarm!!
Any idea's ??
Pete Elite
  • Uxbridge, Middlesex
Re: Alarm on Elite....
« Reply #1 on: 10 August 2007, 01:33:12 »
  Hi,
     Just an idea but have you tried disconnecting the battery(making sure you have relevant radio codes) wait a bit(30 secs.)and then switching on as soon as you reconnect :question.
    Hope this helps,
                          Pete :y.
« Reply #2 on: 10 August 2007, 09:49:50 »
Sounds like the power sounder is getting confused to me. Do you get the full-on alarm with an electrinic siren sound, horn sound and flashing indicators or is it just the electronic siren?
Mine has just died, built-in batteries leaked all over the circuit board giving a few weeks of wierd behavior before it finally packed up. I'd try disconnecting the power sounder (under scuttle cover, driver's side, just behind the suspension turret).
PaulyQ
  • Hartlepool
« Reply #3 on: 10 August 2007, 15:32:49 »
Was just the electronic alarm..... literally for 1 second and then off!!
STRANGE THING....... IT'S STOPPED  :question
« Reply #4 on: 10 August 2007, 15:59:34 »
Sounds a bit like mine. It went through a phase of triggering the main alarm about 15 mins after I parked it up. Then it started doing the 4 pips when ignition turned on. Then it went off and refused to silence a couple of times. Only thing that would silence it is to start the engine, let it run for a few mins to stabilise and then stop it.
Definately a dodgy power sounder. Take it out and cut around the seam to open it up. If it's not beyond saving it will be possible to change the batteries and glue it back together.
PaulyQ
  • Hartlepool
« Reply #5 on: 10 August 2007, 16:02:57 »
thanks for the advice..... gonna buy me an Omega Haynes methinks.... need to get to the guts of this car!! Few things need sorting :-X
« Reply #6 on: 10 August 2007, 16:08:32 »
See if you can pick up Haynes from ebay. Like most modern Haynes, bit crap, but worth having....
PaulyQ
  • Hartlepool
« Reply #7 on: 11 August 2007, 00:26:12 »
LOL... it came back.... and then stopped again!!
I drained the battery last week(music whilst I worked out in the garden) and had to recharge it.... this may have caused the problem in the first place. If it gets any worse I'll just disconnect the battery as suggested above.
« Last Edit: 11 August 2007, 00:26:46 by PaulyQ »
« Reply #8 on: 11 August 2007, 20:17:54 »
The power sounders don't last forever. My late 2002 one has just failed. Could be that draining the main battery was the last straw for the internal battery which will have been pretty weak anyway.
I'd say take the power sounder out. You'll still have an alarm but without the full thatcham functionality as it will rely on the vehicle battery for charge. Leave it in and you never know what its' next trick will be ::)
