Author Topic: Indicator Permanently On  (Read 6069 times)
PJG
  • Tyne & Wear
« on: 16 August 2007, 15:22:39 »
Hi there, recently my R reg Omega 3.0 Elite has developed some Elite electrical gremlins.  The passenger side indicator bulbs are all permanently on (not flashing just on) evenwhen the car is switched off and locked up.  In order to stop attracting the attention of the law and to save my battery I removed a fuse, this fuse also controls the trip computer, the radio, the heater fans and facia, roof lights and the drivers electric seat.  With the fuse out the indicators do work normally hovever when indicating left in time with the flashes the computer, heater fans and lefthand side interior lights also come on and off, most amusing ;D.  I have replaced the flasher unit under as a precaution but this did not change anything :-[. I have tried to locate what I believe is called Board Three which has the alarm relay on it, I believe this could be part of the problem.  My searches have found nothing, nor could I find the alarm control unit (I found the sounder and disconnected it as I had the alarm going off during the hottest time of the day problem).  Please can anyone help :'(
Re: Indicator Permanently On
« Reply #1 on: 16 August 2007, 16:00:15 »
Try a replacement hazard switch ;)
« Reply #2 on: 16 August 2007, 16:07:55 »
Failing that it's the relay that the alarm uses to control the indicators. Don't know where it's located, I'm afraid. Probably on the panel by the cabin fusebox. Sounds like a contact has welded meaning it supplies power continuously and that is feeding back into associated curcuits when you remove the fuse.
PJG
  • Tyne & Wear
« Reply #3 on: 16 August 2007, 16:32:07 »
Firstly thankyou for the speedy response, am very impressed with the forum :y.  I had pulled the hazard warning light switch out before thinking that this could be the problem, however nothing changed :-/.  I do think that the problem is definitley related to the relay that the alarm uses to control the indicators.  The only thing is that I do not know where this is located.  I had a look in the modern Haynes Manual but I may as well have looked for the answer in an old copy of the Beano.  Has anyone got any suggestions or an older Haynes?  Once again thanks for the help :)
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #4 on: 16 August 2007, 16:51:43 »
I seem to remember having this on my other Omega. The relay is behind the glove box. You can either remove the glove box or just the kick panel beneath it. There are a couple of relays there, but not sure which one. Try pulling each one in turn.
Weds
  • Chatham, Kent
  • My other hobby
« Reply #5 on: 16 August 2007, 17:08:00 »
Had another check on Yahoo groups where i originally posted my reply to the problem
Its a grey coloured relay to the left and behind the glove box, GM no
90 060 264
You'll find its part of the alarm system so pulling it will still allow your indicators to work, they just won't flash when locking/unlocking the car
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #6 on: 16 August 2007, 17:29:02 »
I know if you take the hazard warning switch out of the dash the indicators wont work  :-[ as I found out a while ago after taking the dash out to play with the climate control unit  ;)
PJG
  • Tyne & Wear
« Reply #7 on: 16 August 2007, 17:42:31 »
Eureka!!!! It was the little grey bar steward of a relay located behind the glove compartment  :o.  I only wish I had used the forum earlier as I have practically field stripped the car over the last couple of days.  I can now put the car in for its MOT, she has been a good old ship!! a bit like a car version of the millenium falcon, fingers crossed she will pass, thanks again for all the help, Philip :y [smiley=2vrolijk_08.gif]
« Reply #8 on: 16 August 2007, 17:51:26 »
Ahh, glad you've sorted it. I know the relay you're talking about. It's next to the brake light current sensor for the trailer electrics. Glad we know what that relay does now. BTW: Did removing the relay fix it or did you have to put a new one in for the indicators to work again?
Weds
  • Chatham, Kent
  • My other hobby
« Reply #9 on: 16 August 2007, 17:57:38 »
If my memory is correct it only works on the alarm and locking/unlocking for flashing the indicators, so you can still run without it. I found before the relay had contacts had failed inside, replacing the relay should solve the problem.
PJG
  • Tyne & Wear
« Reply #10 on: 16 August 2007, 18:00:33 »
Just in case anyone is interested I took the offending relay apart and found that one of the contacts had snapped and must have made its final resting (explains why the lights behaved oddly for a while before sticking on) place between two other contacts.   [smiley=2vrolijk_08.gif]
PJG
  • Tyne & Wear
« Reply #11 on: 16 August 2007, 18:05:37 »
Yes all that relay does is flash the indicators when the alarm is armed/unarmed, so everything works as normal with it removed, once again thanks for the support!! Cheers Guys [smiley=beer.gif]
« Reply #12 on: 16 August 2007, 21:09:31 »
OK. Just wondered if it had changeover contacts to isolate the indicator / hazard switch circuits or if it just pulls the whole circuit live...
Weds
  • Chatham, Kent
  • My other hobby
« Reply #13 on: 16 August 2007, 21:36:40 »
Just checking the wiring diagram, the relay is K46 which is fed from the anti theft/door locking unit.
2 outputs from this relay feed into the left and right of the the flasher circuit.
« Reply #14 on: 16 August 2007, 23:19:00 »
I know the relay you're talking about. It's next to the brake light current sensor for the trailer electrics. ........
I suppose it depends upon where your trailer check relay lives! As discussed before mine's above the driver's feet.  ;)  ::)  ::)
