Author Topic: Alarm Problem  (Read 2742 times)
r112
  • Bedfordshire
Alarm Problem
« on: 25 August 2007, 21:02:55 »
Can anyone help me, the alarm on my omega keeps going off for no reason, have disconected the battery at has stopped for now but as soon as i re-connect the battery its going off again.  Any idea what is causing this and any solutions?
Cheers.
Rick.
Dazzler
  • Haverhill, Suffolk
Re: Alarm Problem
« Reply #1 on: 25 August 2007, 21:09:32 »
Disconnect the bonnet switch first, then try. If fault persists i have heard that the Power sounders play up on the Facelifts. It may require stripping, cleaning and the battery replacing.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Alarm Problem
« Reply #2 on: 25 August 2007, 21:37:41 »
Hello sounds like the bonnet switch as Dazzler suggests  :y Is it doing it when the sun gets on the car mine only did it when the car got hot sat in the sun  :-? if thats the case it more than likely is the bonnet switch. Lift up the bonnet locate the switch on the 98 2.5s there is a braket on the power steering resivoir this holds the switch not sure if its the same on yours . Either try adjusting the braket or as I did and others have pack the contact point of the switch out on the underside of the bonnet and see if that cures the problem it did mine  :y
r112
  • Bedfordshire
Re: Alarm Problem
« Reply #3 on: 26 August 2007, 10:14:42 »
Hi,
Thanks for the info guys, just to update the alarm itself goes off once its the power sounder that keeps on going, where can i disconnect the power sounder?
Thanks
Rick.
Re: Alarm Problem
« Reply #4 on: 26 August 2007, 11:46:00 »
You need to remove the scuttle panel and it's then on the driver's side on a bracket on the back of the suspension turret.
It does sound exactly like the symptoms I had. The batteries inside the unit had leaked and damaged the circuit board.
