Author Topic: CDR500 - Will it fit in a 1997 Omega 2.0 GLS  (Read 3302 times)
tinker-taylor
  • Aldershot Hampshire
« on: 02 September 2007, 14:34:08 »
 Type:  CD-Radio
 Manufacturer:  VDO
 Brand:  --    Unit Size:  DIN
 Model:  CDR500
 Features:  CD-R/ CD-RW, RDS, Removable Front Panel, Security Code
Can anyone tell me if the above unit CDR500 will fit in to 1997 Omega 2.0 GLS estate with out any problems, it has trafficmaster fitted and I use it - If I buy the CDR500 it comes with the code and instructions leaflet.
Thanks
markey mark
  • SLady bitshorpe north lincs
Re: CDR500 - Will it fit in a 1997 Omega 2.0 GLS
« Reply #1 on: 02 September 2007, 22:47:34 »
will fit no probs ! but the cdr 500 uses steering wheel controls and a full screen mid !! so might not work bud ! have to try and see  :y
tinker-taylor
« Reply #2 on: 02 September 2007, 22:55:13 »
Thanks, I have steering wheel controls, but the screen could be a problem - I will give it a try and see what happens.
« Reply #3 on: 03 September 2007, 11:11:12 »
Should be able to flick the CDR500 between 8 and 10 digit displays using procedure in Maintenence Guides.
tinker-taylor
« Reply #4 on: 06 September 2007, 16:55:22 »
Thanks for the informatiom - I will try this.  [smiley=beer.gif]
« Reply #5 on: 06 September 2007, 17:19:02 »
Yup CDR500 can work with a TID as per Astra, Corsa and Vectra which it was also fitted to.
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #6 on: 08 September 2007, 15:44:53 »
Done it myself on a GLS, straight swop, no probs  ;)
tinker-taylor
« Reply #7 on: 11 September 2007, 00:58:02 »
Thank you, for your help and info.
Working fine.  ;D
