Author Topic: Elite radio, phone question  (Read 5042 times)
Dazzler
  • Haverhill, Suffolk
« on: 22 July 2007, 18:42:20 »
I have just purchased an Elite with a standard Bose radio that has a phone capability. What sim card will fit this unit as my sim card is way to small to fit. Is there an adapter plate that is needed?? or is it to old for todays sim cards :(
The radio system is a CCRT 700, it also says not to use the phone whilst driving, I thought the system was handsfree which means that you can :-/
« Last Edit: 22 July 2007, 19:09:51 by Dazzler »
Re: Elite radio, phone question
« Reply #1 on: 22 July 2007, 19:16:27 »
Full size SIM, must be 900Mhz network though (o2 or voda in uK)
Dazzler
« Reply #2 on: 22 July 2007, 20:17:25 »
Having trouble locating a full size sim card :( I can get a converter to make a normal sim into a full size sim, but will it stay inplace once inserted into the radio????
Is the system good once up and running or is it better to just go bluetooth?? :-/
« Reply #3 on: 22 July 2007, 20:23:21 »
Just order a SIM from O2 or Vodaphone and it will come full size but with the small bit that you'd put into your mobile as a snap out bit in the corner. All SIM used to be full size once!!  ;)
It's very handy & easy to use but compared to modern systems I suppose it's a bit dated now, and you'll have another number. Vodaphone I believe allows you to have 2 SIM cards on the one number (if you're contract) but I also understand that can also be a hassle, as you've to allocate which phone you want to use.
« Last Edit: 22 July 2007, 20:27:41 by Andy_B »
Dazzler
« Reply #4 on: 22 July 2007, 20:32:27 »
I see what The Boy was impling now :-[ Thanks to you both ;)
Bo Bo
  • Coventry
« Reply #5 on: 23 July 2007, 23:07:03 »
If I'm driving any distance I divert my mobile to my carphone, works a treat  :y
« Reply #6 on: 03 August 2007, 19:49:54 »
I use one of the adapters and it works well. The Tesco sim card will work :y
Dazzler
« Reply #7 on: 04 August 2007, 21:18:57 »
Got a Vodaphone card from fleabay with £2 credit for £1.51 delivered. Tried it today , works a treat :)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #8 on: 13 September 2007, 20:28:31 »
Just tried an O2 card in mine, and it just sits there saying Searching :(
even put a tenner on it to activate it!  Still nothing  :'(
Humbugs...
« Reply #9 on: 14 September 2007, 09:08:00 »
presumably a gsm one, not 3g card?
