Author Topic: sat nav speaker  (Read 2938 times)
Mr.Slippy
  • Manchester
sat nav speaker
« on: 22 October 2007, 10:41:24 »
Hi
I'm hoping that my muted sat nav is down to a faulty speaker rather than any other problems with wiring.
The carin system works perfect, except for no voice giving me directions, therefore I have to look at the screen.
I have been to maplins to see if they have stock of similar speakers, they didn't, anyone help me on where to get one from?
Cheers
Andrew
    • 530D M Sport, 330i Coupe
Re: sat nav speaker
« Reply #1 on: 22 October 2007, 15:16:56 »
Presuming this is the Carin system? Does the original speaker have any markings on it? As long as you've got one with a similar impedance and sensitivity I would have thought it would worked.
Can you test the speaker by using another source?
Mr.Slippy
  • Manchester
Re: sat nav speaker
« Reply #2 on: 22 October 2007, 16:26:08 »
no markings I can see, therefore I'm not really sure what source would work best.
its got two spade connections on it that's it!
I do need to try another speaker, but again I'm at a loss as too which is best. Maplins didn't even have a size that matched never mind specs.
Cheers
Re: sat nav speaker
« Reply #3 on: 22 October 2007, 21:04:04 »
Hi
Cheers
Andrew
You have the settings correct then for sound? Obvious I know, but needs to be asked! ;)  ;)   :y
Mr.Slippy
  • Manchester
Re: sat nav speaker
« Reply #4 on: 23 October 2007, 08:09:27 »
yep triple checked the output settings :D
