Author Topic: Got a few probs, traff master, waters, power steer  (Read 7645 times)
garbage456
  • Carshalton, Surrey
« on: 03 November 2007, 11:18:06 »
hi,
three things hopefully all should be quite easy to fix.
(1) on the right side of the dashboard I got a button that says TM, when I press it a woman voice comes on saying Traffic Master is expired call this number 0990 blah blah, quoting account blah blah, does anyone know what Traffic Master is, I have sat nav and that is working perfectly.
(2) I put 1 litre of water in the water jets (because the warning was coming on) all was fine, bit yesterday the warning was on again, so today I put 3 litres in. but now nothing is working either the windscreen or the headlight jets, The noise is still being made though (it was cold last night but not cold enough to freeze I wouldnt of thought)
(3) Is there a power steering fluid in the car, it is not listed in the manual, I have found brake fluid and oil and coolant
Thank you so much for any help you can give.
Re: Got a few probs, traff master, waters, power s
« Reply #1 on: 03 November 2007, 12:11:11 »
1) Traffic Master - Its a system for alerting you to traffic jams and accidents. I found it useless some members here like it, its a personal choice, for an yearly payment you get info on problems around you.
2) The system takes 6 Litres of water, if you have washer jets this can be used VERY quickly. 6L is not enough really. The gauze filter could be blocked.
3) Power steering fluid is the large black bottle on the passenger side towards the rear of the engine bay.
garbage456
« Reply #2 on: 03 November 2007, 13:10:26 »
WOW thanks for the fast reply
(1) Think I will just use the Sat nav then.
(2) Where abouts is the Gauze filter please?
(3) for the power steering is that the one that says somthing like use at a setting temperature of 20oC?
« Reply #3 on: 03 November 2007, 13:47:09 »
Gause filter is in the washer bottle tank, its located between the bumper and tank.
If you car is 1994-1999 (pre facelift) then you need to remove the grill
If its post 1999 (facelift) then no need to.
Put your hands behind the bumper where the number plate is, you will see 2 pipes going into a small motor, pull it towards the bumper then up.
The gauze sits at the bottom.
Think there is a guide on it someware here...
garbage456
« Reply #4 on: 03 November 2007, 13:49:23 »
ok its 2001 I will have a go now, cheers.
Oh I dont think I mentioned there is no water on the floor so it is not leaking hopefully it is filter.
« Reply #5 on: 03 November 2007, 14:35:24 »
water on the floor, inside the cabin or outside?
Water inside the cabin passenger side is usually related to the scuttle drain being blocked.
Outside does suggests a blockage in the gauze.
garbage456
« Reply #6 on: 03 November 2007, 14:36:40 »
hi you mis read it I said there is NO water on the floor haha
garbage456
« Reply #7 on: 03 November 2007, 15:17:14 »
hi just been out to it and the windscreen jets are working now, without taking it off, strange  :-?
although both the headlight ones are not.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #8 on: 03 November 2007, 22:44:19 »
headlight ones only work when the headlights are on
garbage456
« Reply #9 on: 04 November 2007, 10:53:40 »
they only work when headlights are on.
I will try it now, thanks for the advice.
YEP they work.
All I got to do now is adjust the main windscreen ones, a needle should sort them as they are only reaching the bottom of the screen and not the top.
I just noticed my drivers side wiper is smaller that the passenger side, is this normal?
« Last Edit: 04 November 2007, 11:00:08 by garbage456 »
Patryk
  • Gillingham in Dorset
« Reply #10 on: 04 November 2007, 11:16:03 »
YEP they work.
Yes, is normal :y
I am so sorry for my english..
Omega Elite 3.0 saloon '98-my best car...
Passat 1.9TDI estate '04-german crap-I hate it, will be sold soon...
Astra 1.4 '93-the Granny-my first car in UK still with me...
garbage456
« Reply #11 on: 04 November 2007, 11:51:54 »
Thanks for all your help, getting there now.
In my manual it hasnt got my engine number (i think)
The nubmers given are
z 22 xe
y 22 dth
y 26 se
y 32 se
yet i have a 3.0 v6 24v?
is there somewhere on the car I can find out if it is one of these engines?
I am guessing the 22,26,32 actually are 2.2 2.6 and 3.2  engines, or have I got that wrong?
« Reply #12 on: 04 November 2007, 15:36:39 »
IIRC, the drivers side is 24", passenger is 19"
Patryk
« Reply #13 on: 04 November 2007, 16:09:18 »
that right-the drivers is longer :-[
« Reply #14 on: 04 November 2007, 16:11:20 »
z 22 xe
y 22 dth
y 26 se
y 32 se
You are correct.
Using TIS by any chance, as that doesn't carry wiring diagrams for 2.0/2.5/3.0?
