Author Topic: alarm fault  (Read 2477 times)
jockcmtavish
  • Bridlington, East Yorkshire
alarm fault
« on: 07 November 2007, 22:44:24 »
Basically just goes off when it feels like it sounds for 30 seconds then stops.  Most commonly happens when starting the car but has happened when pulling off from a set of lights!!!! and when it has been parked locked for a while.  The car is not immobilsed tho while it is going off and can be started and driven(or doesn't cut out if it was already running).
Any ideas?
Re: alarm fault
« Reply #1 on: 08 November 2007, 12:09:08 »
Power sounder internal battery failing.....
tomoco
  • leicester
Re: alarm fault
« Reply #2 on: 14 November 2007, 10:24:58 »
Yes, sounds like your sounder has duff batteries. Mine used to go off at 3 am. Vauxhall Want 50 quid plus vat for a new sounder. i just disconected mine. As its only a back up sounder ,(just incase somebody disconnects you main car battery) you can unplug it till you get time and money to sort out a new one. You will still have the main alarm horn so your alarm will still sound off.
Mark
Re: alarm fault
« Reply #3 on: 14 November 2007, 18:15:53 »
I concur...
Re: alarm fault
« Reply #4 on: 15 November 2007, 00:00:30 »
Really? That's not too bad actually. Maybe I should replace mine :-/
Dazzler
  • Haverhill, Suffolk
Re: alarm fault
« Reply #5 on: 15 November 2007, 00:09:51 »
I thought thet were about £150 from Vaux and about £75 from Autovaux :-/
