Cdc Safe on a ccr2006
Started by paulr, 22 November 2006, 23:05:07
SteveD
QuoteI would like to run diagnostics on one of these units with this fault.  If anyone has this fault and is passing near me, pop it in and I will see if Tech2 can identify and faults (maybe just needs any DTCs cleared?)
Did you ever get to Tech2 one one of these with this problem? If not you can have my old one when I get a replacement. I've got exactly the same problem which happened when the battery went flat while the car was parked up for a few weeks. Put new battery on and everything else works fine just the darn CD player won't (radio code works ok).
No, I haven't yet.  Its not a common problem, but just common enough to pop up here once in a while...
hotel21
Dave DND
CDC Safe is a very common software fault on the CD Changer. It is basically asking for a Code that cannot be entered. I have the facility to reprogram the unit and repair that software fault. Check out this link for full details
http://ice.dndservices.co.uk/shop_show_item.php/ST/2006/ISS/20/IID/587/PAGE/shop_search_index.php
regards Dave
Radio & Decoding Technician
www.dndservices.co.uk
